Cybertruck NC State Inspection - where?
Seribus
Any NC folks run up on inspection time yet? If so, where are you going and what experience are you running into? Cost?
I'm striking out as I've begin asking around town. SC is over an hour away from me so looking for local areas.
Tfran1521
I'm not there yet but I'm interested in where you go.
Qixer01
Joshua
Hope Mills, NC
CyberTruck
Where you at in NC? I’m in hope mills. Any state inspection station should be able to inspect it. Should only be a safety inspection. $13 I think.
Seribus
Seribus
Fayetteville. Where did you go? Gonna try to knock it out today so I can pay the lovely property tax bill and registration...lol
Qixer01
Joshua
Hope Mills, NC
CyberTruck
I am not to the point of inspection yet. My tag has the orange temp sticker still.
I do all my state inspections in Lumberton, I use to work at a dealership there.
eswimm
Charlotte, NC
Model Y, Cybertruck
It wasn't as bad as I thought. Property tax value of $70,290 for FS AWD, which seemed pretty reasonable given the cheaper base on the non-FS.
Only issue I noticed was the licensed weight is only 7000lbs, which is definitely incorrect. I'm not sure how concerned I should be since it's my first weighted vehicle, but it really should have been licensed for 9000lbs, more if I intended to tow.
Seribus
Seribus
I'd like to get one of the custom plates instead of the regular weighted. Will see if I can. If I remember correctly because the truck was slightly under 7k lbs but over when loaded it fell in the 7k level. I could have remembered all that wrong
Seribus
Seribus
Jiffy Lube - In/out within 15 mins.
I tried to get disabled vet plates, and the DMV told me to kick rocks since the truck "falls into a different weight class". So you may not be able to customize your plates because of retarded draconian DMV laws here.
You can take your truck to any inspection station, but I would caution you to take it to one that you trust. I have had several reasons to not trust anyone but Tesla with my vehicles, (and even they need to be double checked).
If I was you, I would talk to the service manager of the station you choose and tell that there is a special procedure that you will need to walk them though on the shop floor. If they refuse to let you on the floor, walk away and find someone else. They will not care about making sure the truck is in jack-mode.
JURZYDVL
Drew
NJ to NC
2024 FS AWD CT, 2023 M3, 2024 Polaris Slingshot S
Counselor
I got my inspection at Jiffy Lube on MacPherson Church. No issues. I do have a personal plate on my FS...no problem at DMV. You do have to get your permanent plate before requesting the personal plate.
Seribus
Seribus
So you can one with the lighthouse or mountains...etc?
JURZYDVL
Drew
NJ to NC
Counselor
You can only get the white weighted plate but you can personalize it.
Qixer01
Joshua
Hope Mills, NC
CyberTruck
I was able to do a custom DV plate for my FSCB here in NC. I have the weighted tag meow. Custom tag should arrive anytime I hope. Been about two weeks.
