XPEL film options - which did you choose?
mrcyber
Kevin
NJ
2026 Cybertruck
Expel has 3 options. Those that have it, what did you choose?
  • XPEL PRIME CS™: An entry-level, color-stable dyed film that blocks 99% of UV rays, reduces glare, and provides everyday comfort and privacy. [1, 2]
  • XPEL PRIME XR™: A nano-ceramic film that significantly blocks infrared (IR) heat and keeps 99% UV protection while maintaining crystal-clear visibility. [1, 2]
  • XPEL PRIME XR PLUS™: XPEL's premium offering, utilizing multi-layer nano-particle construction to block up to 98% of infrared heat and providing the highest level of UV protection (SPF 1000+). [1, 2]
TWRAPS
Iliya
Bay Area, California
twraps.com
2024 Cybertruck AWD
Nano-ceramic beats dyed film on heat rejection by a pretty wide margin — the IR blocking is the meaningful difference. For everyday comfort in warm weather, it's usually worth the upgrade.
We make a pre-cut nano-ceramic kit for the Cybertruck (side/door windows) if you want another option to compare: https://twraps.com/products/windows-tint-for-tesla-cybertruck — $34.95–$69.95 depending on config.
Whatever brand you go with, make sure the kit is pre-cut specifically for the CT — the curved glass is tricky and generic cuts leave gaps at the edges.
