How hard is it to care for a matte wrapped car?
kosmo886
Brett
Boston, MA
Model X
is it meaningfully harder to care for a car wrapped in matte vinyl vs. satin or gloss? Can you ceramic coat a matte finish? if so, how does that change the situation?
BeyondSlick
Agi
Laguna Hills
Cybertruck Base
I wouldn't recommend ceramic over matte, it would almost convert it to satin. I have really positive experience with Matte Jet Seal from Chemical guys (once every 3 months - applies within an hour) and regular wipe using Meticulous Matte Quick detailer and microfiber. It does offer really good protection against fingerprints, has UV blocker (helps with vinyl lifespan) and hydrophobic features.
XCeilidhX
Drew
Silicon Valley & Surrounds
Model 3, Model Y, CB 047XXX, previously a Model S
Agreed, BeyondSlick.
I second the recommendation for chemical guys matte wrap care products. My wife has a matte pink and matte black wrapped Model 3 which has had a vinyl wrap since 2018. It’s just recently getting to a point where some edges are peeling. You might also want some denatured alcohol for the toughest sap or tarry road grime or stubborn bird droppings on the wrap for spot treatment. Would recommend avoiding all brushed car washes and if you have to do a carwash use the brushless jet variety but our experience is that the more times you go to a car wash with jets the faster your vinyl wrap will weather and age or begin to peel at the edges so home wash with microfiber or hiring someone to do the same by hand is preferred. Having said that, it’s pretty quick and easy to wipe off so less work than hand washing a typical clearcoat metallic paint job in our experience. Depending on how dark the matte wrap color you choose is, you may have to be careful to avoid hard water stains though so wipe the wrap dry quickly and do it in the shade.
My two cents. Hope that helps.
Cheers.
Scarecrow
AR
I can’t imagine it’s meaningfully harder between matte and satin. Gloss, maybe you need/want to more frequently, but the process shouldn’t be any harder.
on the ceramic finish… I was concerned with changing the sheen (I went with satin) and didn’t want the ceramic coating to alter the finish. I asked the installer if I could look at the difference on my vehicle between ceramic and not while applying. I’m sure to those experienced there is a difference, but it was very very subtle and not a concern at all. I would recommend going with the ceramic and if you’re concerned about it changing the appearance, just ask to see it. Maybe have them ceramic the front “grill” and see if you’re good with it. Again, different eyes and opinions, but the ceramic coating didn’t significantly alter the sheen for my tastes. (Satin white vinyl wrap).
