atk0506
Andrew
fort worth, TX
Cyberbeast, Model Y
We’re excited to announce the launch of the CyberCamp Pano, a hard shell roof top tent engineered specifically for the Cybertruck. Built to set up in seconds and designed for all-season durability, it transforms your truck into a complete adventure platform.
360° Panoramic Experience
Unzip the rear windows, tuck them neatly under the mattress, and open the side windows to enjoy a true 360° view. From sunsets to stargazing, the CyberCamp Pano gives you an unmatched connection to your surroundings.
Light Up the Night
Two built-in LED light bars deliver even, customizable lighting inside the tent. USB-powered, with both warm and white options, plus ten brightness levels to match the mood.
Materials and Construction
  • Upper fabric: 300D elastic silk breathable fabric reduces condensation during changing temperatures.
  • Lower fabric: Terrace mode opens the door and both side windows for maximum airflow. Compatible with outdoor AC vents.
  • Awning: Fully removable, supported by hidden carbon fiber rods for a clean design.
  • Hardware: Carbon fiber and titanium rods with slam latches and safety pins for security on the move.
  • Shell: Alloy composite with frosted finish, reinforced by aircraft-grade aluminum. Built to handle weather, heat, cold, and impact.
Sleep Comfortably
  • Hybrid Mattress: 3.25-inch pad open-cell polyurethane foam.
  • Base: Waterproof, dustproof Oxford cloth.
  • Inflation: 14,000 Pa pump inflates in one minute and deflates in two.
  • Removable: Mattress can also be used at home.
Quick Open and Close
  • Open: Unlock, slide the switch, and the tent fully deploys in under 10 seconds.
  • Close: Pull ropes and engage slam latches to secure both ends in under 10 seconds, from one spot.
Smart Features
  • Dynamic Pulley System: Close the tent from inside without stepping out.
  • Stabilus Gas Springs: Trusted brand used in Porsche and Mercedes for smooth, reliable lift.
  • Double-layer windows: Mesh interior plus waterproof outer layer, sealed with SBS zippers.
  • Integrated storage: Side compartments and a pocket designed to hold a power bank for the LED lights.
  • HVAC Ports for Climate Control Stay comfortable year-round with HVAC ports designed to work with portable heating or cooling systems, allowing efficient airflow management in any season in your Cybertruck Roof Top Tent.
Specifications
  • Sleeps: 2
  • Interior: 83" L x 46" W
  • Exterior (closed): 91" L x 52" W
  • Height (closed): 7” center, 5” sides
  • Max headroom (open): 45"
  • Weight: 145 lbs
Included with CyberCamp Pano:
7.5' ladder, universal mounting kit, textile chaise lounge, two detachable shoe/gear pockets, two LED lights, and two carbon fiber awning support rods.
The CyberCamp Pano is designed to match the Cybertruck’s strength, speed, and utility - delivering comfort and capability wherever the road takes you.
Will that cybercamp pano only work specifically with a Urander rack?
Urander
Urander
urander.com
It’s compatible with most racks on the market, and this is how we mount it to our crossbar. Do you happen to have the measurements of your crossbar so we can help double check?
Tesla Cybertruck Introducing Urander CyberCamp Pano - 360° Panoramic Cybertruck Roof Top Tent RTT IMG_2178
Tesla Cybertruck Introducing Urander CyberCamp Pano - 360° Panoramic Cybertruck Roof Top Tent RTT IMG_2179
Urander
Urander
urander.com
Here’s the number from our last Bay Area to LA trip, right before the hill. We will share video soon.
Here are some pic of a 7ft garage. We’ll try to find a 6’8” one and share it here too.
You can leave the bedding and ladder inside when the hybrid mattress is deflated, or keep the mattress inflated and just leave the bedding in the bed. Just can’t do both at the same time.
We’re still working on our 3.14’ tall full-length tent and will share pics later this month😊
We just shared a range test video
Urander
Urander
urander.com
Camped with the Pano tent last night in New Mexico on our way back from Starbase to the Bay Area, just 1.5 miles from a V4 charger on BLM land which made it really convenient.
Tesla Cybertruck Introducing Urander CyberCamp Pano - 360° Panoramic Cybertruck Roof Top Tent RTT IMG_4991
Tesla Cybertruck Introducing Urander CyberCamp Pano - 360° Panoramic Cybertruck Roof Top Tent RTT IMG_4989
Urander
Urander
urander.com
Camped at Buttonwillow Raceway last night. It’s about a mile off the I-5, and I haven’t seen anyone else charging here the past three times I’ve stopped. Might actually be a great spot to camp with a supercharger?
Tesla Cybertruck Introducing Urander CyberCamp Pano - 360° Panoramic Cybertruck Roof Top Tent RTT IMG_5106
Tesla Cybertruck Introducing Urander CyberCamp Pano - 360° Panoramic Cybertruck Roof Top Tent RTT IMG_5110
Urander
Urander
urander.com
Bed cap, hardshell 270 awning, pano tent , shower tank, starlink mini and more to come
