- Dec 26, 2023
- CA
- Website
- urander.com
- Cyberbeast
- Thread starter
- #1
We’re excited to announce the launch of the CyberCamp Pano, a hard shell roof top tent engineered specifically for the Cybertruck. Built to set up in seconds and designed for all-season durability, it transforms your truck into a complete adventure platform.
360° Panoramic Experience
Unzip the rear windows, tuck them neatly under the mattress, and open the side windows to enjoy a true 360° view. From sunsets to stargazing, the CyberCamp Pano gives you an unmatched connection to your surroundings.
Light Up the Night
Two built-in LED light bars deliver even, customizable lighting inside the tent. USB-powered, with both warm and white options, plus ten brightness levels to match the mood.
Materials and Construction
Sleep Comfortably
Quick Open and Close
Smart Features
Specifications
Included with CyberCamp Pano:
7.5' ladder, universal mounting kit, textile chaise lounge, two detachable shoe/gear pockets, two LED lights, and two carbon fiber awning support rods.
The CyberCamp Pano is designed to match the Cybertruck’s strength, speed, and utility - delivering comfort and capability wherever the road takes you.
Light Up the Night
- Upper fabric: 300D elastic silk breathable fabric reduces condensation during changing temperatures.
- Lower fabric: Terrace mode opens the door and both side windows for maximum airflow. Compatible with outdoor AC vents.
- Awning: Fully removable, supported by hidden carbon fiber rods for a clean design.
- Hardware: Carbon fiber and titanium rods with slam latches and safety pins for security on the move.
- Shell: Alloy composite with frosted finish, reinforced by aircraft-grade aluminum. Built to handle weather, heat, cold, and impact.
Sleep Comfortably
- Hybrid Mattress: 3.25-inch pad open-cell polyurethane foam.
- Base: Waterproof, dustproof Oxford cloth.
- Inflation: 14,000 Pa pump inflates in one minute and deflates in two.
- Removable: Mattress can also be used at home.
- Open: Unlock, slide the switch, and the tent fully deploys in under 10 seconds.
- Close: Pull ropes and engage slam latches to secure both ends in under 10 seconds, from one spot.
Smart Features
- Dynamic Pulley System: Close the tent from inside without stepping out.
- Stabilus Gas Springs: Trusted brand used in Porsche and Mercedes for smooth, reliable lift.
- Double-layer windows: Mesh interior plus waterproof outer layer, sealed with SBS zippers.
- Integrated storage: Side compartments and a pocket designed to hold a power bank for the LED lights.
- HVAC Ports for Climate Control Stay comfortable year-round with HVAC ports designed to work with portable heating or cooling systems, allowing efficient airflow management in any season in your Cybertruck Roof Top Tent.
Specifications
- Sleeps: 2
- Interior: 83" L x 46" W
- Exterior (closed): 91" L x 52" W
- Height (closed): 7” center, 5” sides
- Max headroom (open): 45"
- Weight: 145 lbs
