Musk drives FSD Beta in Palo Alta
PilotPete
Pete
Porsche, BMW, M3LR on order
Chief Pilot
Yeah, the Tesla nav loses it's mind when connectivity drops. This is not going to work for Cybertruck.
They need to cache the maps, and remember your GPS tracking data, so that you can at least backtrack to where you DID have connectivity.
With the new ML/AI, maps aren’t necessary once it knows the route from A to B. (Eventually, not even that) It’s exactly like a human would do it. It will look for signs (I-10 East to BFE) and then what are the lanes choices. And away it goes. The training that is going on is just like a 16 year old learning to drive. It’s going to watch how people do it, and then imitate what it saw when it is in control. And as for the Stop Signs, it will learn not only what a “full stop” looks like, but what a stop sign looks like, what to do when you come up to one, and who goes first and second, Once it knows the route, you’re set. Connectivity is not needed. This is another part of the beauty of ML/AI over millions of lines of code.
So the question comes to off-road. IF it sees enough training to recognize rocks v sand v water v mountains, and it has learned you can drive over all these things (with exceptions) then even with a loss of connectivity it should be able to get you there, in the same way you would do it.
RVAC
FSD knows where it is at all times. It knows this because it knows where it isn't. By subtracting where it is from where it isn't, or where it isn't from where it is, it obtains a difference, or deviation. The navigation system uses deviations to generate corrective commands to drive from a position where it is to a position where it isn't, and arriving at a position where it wasn't, it now is. Consequently, the position where it is, is now the position that it wasn't, and it follows that the position that it was, is now the position that it isn't.
charliemagpie
Charlie
CybrBEAST
It's amazing.
K.I.T.T. is real.
And so are C-3PO and R2-D2
MiguelAznar
Miguel
Cybertruck 3-motor
Thanks, Tweedledee!
(Contrariwise,' continued Tweedledee, 'if it was so, it might be; and if it were so, it would be; but as it isn't, it ain't. That's logic.)
charliemagpie
Charlie
CybrBEAST
I know where it is...
Cybertruck is on first
RVAC
As a meme it sorta fails because... that's how advanced gps works. Both are self-guided self-propelled machines using basically the same methods.
The meme is the convoluted explanation, not that it isn't true. Cybergus mentioning FSD having to backtrack from where it is to where it knows it isn't (point of GPS loss) reminded me of it.
To be honest, it is rather convoluted, the different levels in GPS itself.
And then it has to match what it sees around it to what it knows should be nearby.
FutureBoy
Reginald
Kirkland WA USA
Toyota Sienna
Financial Advisor
OK... This thread (well, just the title) is driving me nuts.
Current title:
Please for the love of god, please fix that city name!!!!!!!!
It should be:
Musk drives FSD Beta in Palo Alto
Sorry, but I just keep getting stuck on that name....
@CoachTerry or an @Administrator please!!!!
Stuck4ger
Cape Canaveral, FL
Aerospace
But does it know where the missile is?
