NEED HELP - Egg off PPF
The Tumbler
AJ
Alamo, ca
2024 Cybertruck FD series Dual Motor AWD
Real Estate Broker
Need some help… some entitled rich kids in a golf cart egged my truck while it was out front of my friends house. I can’t get it off with soap or ppf spray cleaner. Does anyone know of a product that will take the egg off the PPF without ruining it?
UberNoob
CyberBeast & M3P
Desktop Security Engineer
Bisquits and bacon ? should do it. Jokes aside, the egg is likely dried on there, you will have to rehydrate it somehow, keep it moist, dish soap etc, should start wiping up. Dont scrub to not damage the PPF. Use something forgiving like a soft sponge ?. Treat it like your cleaning display screen.
XCeilidhX
Drew
Silicon Valley & Surrounds
Model 3, Model Y, CB 047XXX, previously a Model S
I don't know specifically about PPF, but with vinyl wraps when I have had things like this I have used a microfiber cloth with denatured alcohol with success in the past but you may want to test it on an obscure place first to make sure it doesn't do anything to the wrap.
Hope that helps.
Cheers
The Tumbler
The Tumbler
AJ
Alamo, ca
Real Estate Broker
Thank you for the advice. I found the 14 year old boys who did it. Gave them a nice lecture, called their dad and met with him. He will make it right. I tried the warm vinegar and water soak. Didn’t work. However this PPF stuff is pretty remarkable… it’s been in the sun today and seems to be self healing all the marks out. Will see if it goes away 100%
The Tumbler
The Tumbler
AJ
Alamo, ca
Real Estate Broker
I’m very lost at this… The CT hate around here in California seems to be mostly coming FROM the Maga dopes, even though Elon seems to be their new lead donor. Don’t get it. People have limited intelligence and respect.
Stickercity
Dean
Teslay model 3
After Market Automotive Services
Your truck
Removing egg from Paint Protection Film (PPF) requires a careful approach to avoid damaging the film. Here’s a step-by-step guide:
Materials Needed:
  • Warm water
  • Mild car shampoo or dish soap
  • Microfiber towels
  • Soft-bristle brush (optional)
  • Isopropyl alcohol (if necessary)
  • Spray bottle
Steps:
  1. Act Quickly: Egg can be corrosive and can damage PPF if left for too long. Address the issue as soon as possible.
  2. Rinse with Warm Water: Use a spray bottle filled with warm water to gently rinse off as much egg as possible. Avoid using high-pressure water, as it may damage the PPF.
  3. Prepare a Soap Solution: Mix a few drops of mild car shampoo or dish soap with warm water in a bucket.
  4. Soak a Microfiber Towel: Dip a microfiber towel into the soapy water, then gently lay it over the affected area. Let it sit for a few minutes to soften the egg residue.
  5. Gently Wipe the Area: After soaking, gently wipe the area with the microfiber towel. Use a soft-bristle brush for stubborn spots, being careful not to scrub too hard.
  6. Rinse Thoroughly: Rinse the area with clean, warm water to remove any soap residue.
  7. Inspect the Area: Check for any remaining egg residue. If some remains, repeat the soaking and wiping process.
  8. Use Isopropyl Alcohol (if necessary): For any remaining stubborn residue, dampen a microfiber towel with a small amount of isopropyl alcohol and gently wipe the area. This should help break down the remaining egg without harming the PPF.
  9. Final Rinse and Dry: Give the area a final rinse with clean water and dry it with a fresh microfiber towel.
Additional Tips:
  • Avoid using abrasive materials or harsh chemicals that could damage the PPF.
  • If the egg has been on the PPF for an extended period and has caused staining or damage, you may need to consult a professional detailer for further assistance.
By following these steps, you should be able to safely remove egg from your PPF and maintain the integrity of the film.
The Tumbler
The Tumbler
AJ
Alamo, ca
Real Estate Broker
Your truck
Materials Needed:
  • Warm water
  • Microfiber towels
  • Spray bottle
Steps:
Additional Tips:
Thank you. This is a great rundown. I did this pretty much to a T except for the IPA. It got most of it off but still left a silhouette residue. I’ve repeated and the self healing PPF properties seem to be fading the residue. Fingers crossed it comes all the way out.
Stickercity
Dean
Teslay model 3
Make sure if you do use the alcohol to mix it with water and make sure you are in the shade and the panel is not hot. You can also try some PPF non abrasive quick detailer. Let me know how it goes
