No power via rear USB-C Ports ?
L3it3R
Chris
Maryland
AI | Software | Sales | etc.
does anyone know what voltage & amperage is available from the rear usb-c ports?
More specifically, can I run the Starlink mini from here which requires 20V/5A?
Thanx ever so, Paul
You can use a pd60 barrel jack adapter to run the Starlink mini - the Starlink USBC cable is a pd100 and will NOT work. The good thing is the barrel jack adapter is about $3.50 each.
This is the one I use:
https://amzn.to/3H1ASHw
Reactions: REM
ecotrials
Paul
Lafayette, CA (SF Bay Area)
GMC Sierra, electric trials bike
Thank you for trying, I had already looked it up here. What am I missing?
I found:
CAUTION
Do not use the USB-C ports to power a device with a power rating that exceeds the limits listed above.
Unfortunately I do not see the ratings listed above anywhere…..
I would like to find nnVolts and names to be sure.
Also thanx to whomever supplied the Amazon part number. Does this actually work consistently or is it hit and miss? That is stated 65W versus Starlink spec of 100W?
Paul
L3it3R
Chris
Maryland
I found:
CAUTION
Paul
It works PERFECTLY. the mini only draws like 35w
I’ve had it on literally all day MANY times
Reactions: REM
