- A. J.
- Dec 8, 2019
- Virginia/Quebec
- Tesla X LR+, Lexus SUV, Toyota SR5, Toyota Landcruiser
- EE (Retired)
Nobody knows exactly and that is perhaps why so many choose the % SoC display rather than the miles or km one. If you do this the little battery symbol display becomes just like the familiar gas gauge we are all used to. Just as you had some idea as to how far you could go in your ICE car with a quarter of a tank of gas remaining (though you probably didn't pay that much attention to it) you will develop an idea as to how far you can go in your BEV on a quarter of a charge and how that varies with road conditions, terrain and weather. You will become sensitized to these things.The most critical screen display, namely "Distance Remaining," is based on exactly what?
But to try to answer your question: the vehicle is constantly estimating the state of charge (SoC) of the battery. Exactly how this is done no one except Tesla really knows but it is probably a combination of coulomb counting (almost every coulomb that goes in comes out) and checking battery open circuit voltage. In % mode it simply displays SoC but in range mode it tries to turn that into miles by calculating the charge and dividing by the miles per kWh. For the driver sub display the consumption is evidently the EPA rated consumption but if you go to the energy display in consumption mode uses the consumption calculated over the last fraction of a mile, a 5 mile, 15 mile or 30 mile window per the drivers choice and tells you want that consumption estimate was. Thus you may have two ranges displayed that are not the same, one next to the battery indicator and a different one on the main console energy display. The energy display in trip mode shows the estimated SoC at destination but you must, obviously, have a destination punched in for this to work. In this mode the destination SoC estimate depends on the average consumption over the selected window and the terrain ahead of you on the selected route. This is the most accurate estimate you will get but depends on future driving conditions being the same as those that you have encountered up to the current point in time. This is an extremely useful display as it shows you what the trip planner originally figured, how you battery use history compares to that and gives you an estimate as to what you will have when you get there. In the X you get about 3 miles per percent on average so if you have an estimated SoC at arrival of 10% you figure you will have about 30 miles margin - perhaps 20 if things don't go well and perhaps 40 if you pick up a tail wind, This makes for total victory over range anxiety one you learn how to read the displays.
Yes, I think so as noted above.Battery voltage?
Yes, I expect so as low ambient temperature effects drag though not dramatically and drag is not usually the biggest consumer of energy, But note that if drag does increase consumption that will be caught in the average Wh/mi calculation and will be reflected in the energy display screens but not on the battery indicator reading.Ambient temp?
These too will be reflected in the energy screen display.Distance driven? Load aboard? Recent driving pattern (e.g., hilly terrain, trailer towing, max acceleration)?
Clearly if you are predicting 20 miles the variance in the estimate is going to be lower than if you are predicting 200 miles out. So yes, the closer you get to destination the more accurate the prediction is. The display shows two lines - one for the initial prediction and one for the actual drive history. The terminal ends of those two curves are often several SoC percent apart.And does it show more readout-sensitivity when within, say, the last 20 miles?
