Replacement tire price will be a shock
ldjessee
Lloyd
Indiana, USA
And I was also hoping to buy barely used CT tires for those who upgraded (common practice in many trucks, especially Jeeps). But with so many planning on doing so, probably will be priced out of my budget.
I hope someone builds something with a Raspberry Pi that connected to some solenoids and that are able to read the TPM units, could control deflate and inflate tires... could do the inflate using a manifold and the solenoids to switch which tire it is airing up until they all are at the right pressure. Oh, and a way to monitor/change settings from a phone... that is important as well.
I think many in the Jeep community (and other off-roaders) would like something like that...
now, who is going to make that? ;)
SwampNut
Carlos
Peoria, AZ
Tesla M3LR, Gladiator Rubicon
Geek
That already exists. I chose to roll my own compressor system and make it semi-manual because the automation offered little value. My system uses a simple $10 pressure switch to stop filling when all the tires hit 35. But I could have spent $500 on a phone/BT version, which gains ... nothing.
SwampNut
Carlos
Peoria, AZ
Geek
Then you can choose to spend the $500. I don't know what "between vehicles" means since the system is mounted on one vehicle. The UI to let you know the compressor isn't plugged in is that it makes a whirring noise when it is.
SwampNut
Carlos
Peoria, AZ
Geek
That's shown on the TPMS display, and is also shown in the vehicle app. Do I want to know more than that? No.
The automated compressor system with BT simply tells you what pressures are being supplied WHILE the compressor is plugged in to the tires, and to set the pressure. Which is silly since it's always the same. For air-down, the TPMS automatically goes into a constant display. Also pretty useless, since anyone who wheels a lot just carries pre-set air-down chucks.
Tesla Cybertruck Replacement tire price will be a shock 1628528565560
SwampNut
Carlos
Peoria, AZ
Geek
And I absolutely LOVE automation and connectivity. My house and life are very automated. I have three Raspberry Pis in the house and another in the Tesla to run Teslacam and let me access the car over wifi. But...it has to add value. Can't find value in that compressor system.
