What UI changes would you love to see?
Unlock the other 7 levels of the ventilated seats.
Currently 3 bacon strips on ventilated seats feels like level 3/10 unlock the rest please Telsa because 30% feels like nothing compared to M3 MY or my cousins 40k Honda.
Yes. MORE bacon.
How about adding garage open/close and glovebox buttons to the little top tool bar next to driver profile that don’t require opening a menu.
BabOne
Brian
Tucson, AZ
CyberTruck AWD and Ford F150 Limited
A very basic no brainer - keep the rear view mirror camera on the screen when turn signal is used.
If I understand you correctly you can change the setting to keep the rear view camera on so it does not change to the side camera when using the turn signal. That is my preference.
Tesla Cybertruck What UI changes would you love to see? tempImage0sNuwD
It should display both.
Cybermo
Mo
Malibu
Cybertruck AWD, Range Rover Classic
Director
This definitely was added recently because I've looked many times before. I'll try it out, thank you!
Limes2
Chicagoland
2025 Cybertruck AWD
Eliminate the toggle to turn the bed outlet on by using the outlet door sensor to turn them on or off automatically.
Shouldn't have to go into the screen, just open the door and plug your tools in.
That’s a great idea. You could add that as a check box option in case someone doesn’t want that for whatever reason.
MisterTea
MisterTea
Tyson
NJ
Make the offroad rear camera mode the standard. I like how it shows the little squares for side view cameras.
This would be a great solution for the rear camera display. I'd love to see just the rear camera and then when I put a blinker on, that side cam slides next to the rear camera instead of replacing it.
Cybermo
Mo
Malibu
Director
All right so I just checked it out, it most definitely does not display both, I already had automatic blind spot camera turned on as well. I'm trying to have the rear view digital mirror on the screen along with the blind spot camera when I'm signaling.
Another suggestion would be an automatic camera that turns on when you're coming into a parking spot a la Porsche.
