Windshield Wow, my "recipie" thats great for haze
evlfred
Monte
Idaho Falls
2026 CT Premium 2026 Model Y Launch
for this "recipe" you'll need the following
1 Windshield Wow Kit https://windshieldwow.com/products/gift-set
1 Long Reach Pole Accessory https://windshieldwow.com/products/long-reach-pole-accessory
1 Ultra Plush Microfiber Cloths https://windshieldwow.com/products/ultra-plush-reusable-microfiber-cloths
1 Haze and Film Erasers https://windshieldwow.com/products/wow-magic-sheets
1 Broom Handle for the Pole Accessory
1 Favorite Glass cleaner, I use Perfect Glass Spray https://a.co/d/03QhJqlO
Optional Magnetic Retriever tool https://a.co/d/0c2YsdoE (you WILL knock off the inside pad and it WILL stick to the speaker grill, at least until you get the hang of it) I just keep this in my center console
Here's the procedure:
1 Put the yellow ultra plush cloths on both the outside Windshield Wow and the inside one, and wet the inside one with glass cleaner.
2 clean the entire windshield top to bottom overlapping each swath by half, reapply cleaner as needed. Use caution near the bottom, sides, and around the camera pod as you can knock the inside pad off easily. If this happens at the front use long arms or the magnetic retriever to get it off the speaker grill just don't lift up and hit the glass.
3 Switch to a dry yellow cloth and repeat
4 Put one of the haze and film eraser sheet on the inside dry yellow cloth and repeat
5 enjoy haze free windshield for about a month
Takes about 5-10 minutes once you get the hang of it.
Limes2
Chicagoland
2025 Cybertruck AWD
True for new CTs and then about after a year the off gassing will slow down. You then only need to clean the interior every couple of months or so.
Another tip. From your video, you are doing this in the shade. When you are done, move it to a sunny spot to check your work.
