Langestreet
Richard
SW WA
Cybertruck, Model Y, Excursion,+++
Mostly Retired :-)
Epic Cybertruck Towing Adventure: Round Trip from Vancouver, WA to Lander, WY with an Airstream Basecamp 20XE
Hey fellow Cybertruck owners! I just returned from an incredible multi-day round-trip adventure towing our Airstream Basecamp 20XE with the Cybertruck, wrapping up on September 30, 2025, at 5:15 PM MDT. We covered 2200 miles from Vancouver, Washington, to Lander, Wyoming, and back via Interstate 84 through Salt Lake City, for a wedding in Lander. This was our first long-distance tow with this setup, crossing the Continental Divide twice at around 7500 feet each way, and it showcased the Cybertruck’s towing prowess with an impressive average energy consumption of 769 Wh/mile. This efficiency is remarkable for a 4000-pound trailer over such challenging terrain with sparse charging infrastructure. Here’s the full breakdown for tech enthusiasts and those curious about towing with a Cybertruck!
Tesla Cybertruck Epic Cybertruck Towing Adventure: Vancouver WA to Lander WY with Airstream Basecamp 20XE over Continental Divide DJI_20250926100757_0291_D
The Setup: Cybertruck + Airstream Basecamp 20XE
Our rig was the Cybertruck Dual-Motor AWD towing an Airstream Basecamp 20XE, a compact 20-foot travel trailer with a dry weight of about 4000 pounds (UVW 3500–4200 lbs depending on options). Its sleek, aerodynamic aluminum profile minimizes drag and looks stunning behind the Cybertruck. The Basecamp 20XE is Airstream’s first all-electric-capable trailer, built for off-grid adventures with a fully inverted 30A electrical system. Key specs include:
  • Power System: 10 kWh heated lithium Battle Born battery bank with remote monitoring and a 3000W pure sine wave inverter for seamless 12V-to-110V conversion. Charged via the trailer’s standard 30A shore power circuit—efficient and straightforward, no active axle or regenerative braking needed.
  • Solar Integration: 600W of flexible rooftop solar panels to keep batteries topped up during boondocking, ideal for remote Wyoming campsites.
  • Electric Appliances: Embedded induction cooktop in the quartz countertop, electric on-demand water heater, and ducted Truma Combi Eco Plus furnace (15000 BTU electric mode with LP gas backup). These kept us comfortable and emission-free, with gas as a backup for colder nights.
  • Off-Road Ready: The XE’s 3-inch lift (over standard Basecamp models) provides up to 14 inches of ground clearance, making it agile on rough terrain and nimble in tight campsites. We towed using a 2 5/16-inch ball with a 2-inch rise on the receiver to keep the trailer level—no weight distribution hitch or sway control needed. This combo was a head-turner at every stop!
Towing Performance
Towing with the Cybertruck was effortless, powered by its Dual-Motor AWD delivering approximately 740 lb-ft of motor torque and an estimated 11000 lb-ft at the wheels, making it a towing powerhouse. We cruised at 50–60 mph using adaptive cruise control, which kept our speed steady and optimized range by reducing driver variability. Note: Full Self-Driving (FSD) isn’t available while towing, but adaptive cruise control handled the job superbly.
Without a trailer, the Cybertruck typically consumes around 500 Wh/mile with a Urander rack and awning. Towing the Basecamp 20XE, we averaged an outstanding 769 Wh/mile over the 2200-mile round trip, calculated from 1893 kWh consumed over 2464 miles (based on attached data: Lifetime Energy Used from 9097 kWh to 10990 kWh, and Odometer from 12434 mi to 14898 mi). This efficiency is exceptional, especially considering we crossed the Continental Divide twice at 7500 feet, tackling significant elevation changes (up to 126 meters) and varied conditions. Our most efficient leg was a downhill stretch with a tailwind, hitting 520 Wh/mile, while the most demanding was climbing a mountain pass, peaking at 1200 Wh/mile (see attached data for details).
Achieving 769 Wh/mile while towing a 4000-pound trailer over the Continental Divide twice at 7500 feet highlights the Cybertruck’s remarkable engineering. This figure aligns closely with our previous Oregon coast trip (750 Wh/mile) and underscores its capability for long-distance towing with minimal energy penalty.
Onboard Range Estimates: A Note of Caution
The Cybertruck’s onboard range estimates were initially conservative. At the start of each leg, the state-of-charge (SOC) predictions suggested a much lower range than we achieved, often climbing 20–30% higher by the end of a segment. Driving below 60 mph likely outperformed the system’s assumption of higher speeds (around 65–70 mph). By monitoring Wh/mile in real-time via the onboard display, we refined our range estimates as we drove. For towing, don’t rely solely on initial SOC projections—driving conservatively can significantly extend your range, as evidenced by our efficient 769 Wh/mile average over the Continental Divide.
Charging and Route Planning
Navigating sparse charging infrastructure required careful planning, especially with the added challenge of crossing the Continental Divide twice at 7500 feet. We relied on Tesla Superchargers where available but supplemented Tesla’s charging database with PlugShare to locate additional stations. PlugShare was a game-changer, helping us identify reliable ChargePoint, EVgo, and Electrify America stations for CCS charging in areas without Tesla chargers. This flexibility allowed shortcuts that saved time, though we skipped a Yellowstone loop due to a 9500-ft mountain pass with a 10% grade. Without sufficient data on that grade and limited charging options, I prioritized safety (and marital harmony—my wife was grateful to avoid range anxiety!).
The Basecamp’s 10 kWh battery bank powered its systems (lights, fridge, fans) off-grid without draining the Cybertruck, and the 600W solar kept us sustainable during downtime. The attached data file includes segment-by-segment energy consumption (uphill vs. downhill) for tech enthusiasts to analyze via Tessie or other tools. The 769 Wh/mile average is a testament to the Cybertruck’s efficiency, even under the strain of towing over mountain passes.
Tesla Cybertruck Epic Cybertruck Towing Adventure: Vancouver WA to Lander WY with Airstream Basecamp 20XE over Continental Divide DJI_20250923141357_0281_D
The Experience
This round trip was a blast, not just for the drive but for the reactions we got. At nearly every charging stop or campsite, people asked about the Cybertruck and Airstream combo. One skeptic said it changed his mind about the Cybertruck’s “terrible” look! Airstream owners were especially enthusiastic, and we met other Cybertruck owners and a Tesla Energy service engineer who maintains chargers in Wyoming and northern Colorado. Their insights were invaluable.
The trailer’s 3-inch lift and adventure-ready interior (rear kitchen, wet bath, convertible dinette/bed) paired perfectly with the Cybertruck, both functionally and aesthetically. The electric-first design kept us comfortable without gas reliance, though LP backups were handy for the furnace on chilly nights.
Tesla Cybertruck Epic Cybertruck Towing Adventure: Vancouver WA to Lander WY with Airstream Basecamp 20XE over Continental Divide 20250925_142303
Tips for Cybertruck Owners Towing
  • Don’t be intimidated! The Cybertruck’s 11000 lb-ft of wheel torque makes towing a breeze, even over the Continental Divide at 7500 feet.
  • Plan for 769 Wh/mile with a similar trailer (4000 lbs, aerodynamic) for conservative range estimates, especially for routes with significant elevation changes.
  • Track Wh/mile in real-time to adjust for the onboard system’s initially low range estimates—driving under 60 mph can boost actual range.
  • Use PlugShare alongside Tesla’s charging database to find non-Tesla chargers for more route options.
  • Leverage the trailer’s independence: With 10 kWh batteries and 600W solar, off-grid stays are easy without taxing the truck.
  • Check trailer height: The 2-inch receiver rise was key for leveling our Basecamp 20XE.
  • Cruise control is your friend for consistent speed and better range.
Final Thoughts
This round trip showcased the Cybertruck Dual-Motor AWD’s towing prowess, with 740 lb-ft of motor torque and 11000 lb-ft at the wheels, paired with the Airstream Basecamp 20XE’s cutting-edge electric capabilities. Achieving an average of 769 Wh/mile while towing 4000 pounds over the Continental Divide twice at 7500 feet is nothing short of impressive, highlighting the Cybertruck’s efficiency and power in challenging conditions. It’s a killer combo for adventure, blending power, efficiency, and style. I’ve attached photos of our charging setups (not all stations are equal!) and a data file for those who want to dive deeper. Feel free to ask questions in the comments—I’d love to help anyone considering towing with their Cybertruck. Get out there and hit the road; this truck is a beast!
Safe travels,
Langestreet
Langestreet
Richard
SW WA
Mostly Retired :-)
We dropped the trailer about 25% of the time. There were a couple of times when we blocked other chargers, but only when activity was low and would not affect others.
RoboTaxi
Kansas
Beast when the gods bless me
I’m going to have to do a one time tow of a classic 33’. Hopping to get 100-110 mile range¿. Towing suck balls but I bought this more as a sports truck. In that category it’s great. Thank you for chiming to keep it at 60mph. I’ve read great results in doing that.
Langestreet
Langestreet
Richard
SW WA
Mostly Retired :-)
I think the onboard calculator is calibrated for a box trailer at the speed limit. The Airstream consumption at 60 was astonishingly good.
You forgot the balloon
Tesla Cybertruck Epic Cybertruck Towing Adventure: Vancouver WA to Lander WY with Airstream Basecamp 20XE over Continental Divide Screenshot 2025-10-02 at 5.19.01 PM
Trekboy
Redding, CA USA
Tesla Model 3, Cybertruck
This is why I love this forum. Real world comments about things I'm interested in. I bought my Cybertruck so I could move up from my popup trailer to a slightly bigger RV (which I have yet to do) because my 4runner wasn't quite up to the task. All info is good info in my book. Thanks for your excellent write-up.
FL370
Anders
San Diego, CA
Tesla MS AWD Cybertruck
High Speed Aluminum Transportation
I ended up with around 750kWh over 2400 miles towing a 6k gw adventure camper doing mostly below 60 mph. San Diego, inland Bay Area, avenue of the Giants redwoods, Crescent City by Oregon, Crater Lake, Lassen National Park, Lake Tahoe, Mammoth Lakes, Alabama Hills, back to San Diego. Epic trip where the truck did phenomenal.
jbuijk
Jan
Minesing
S85D, Cybertruck (Nov 24)
Towing Performance
The Experience
Final Thoughts
Safe travels,
Tesla Cybertruck Epic Cybertruck Towing Adventure: Vancouver WA to Lander WY with Airstream Basecamp 20XE over Continental Divide IMG_0373
We have done several trips this summer towing a 30' Airstream. Fresh water tank filled up with 50 gallon of water, 4 adults and a toddler in the CT, all the gear required for a couple of days boon docking. Energy consumption has been consistently under 800 Wh/mile (500 Wh/km).
Shaney84
Sam
Vancouver, WA
Cybertruck, Model 3
Healthcare
This is awesome. As a fellow Vancouver, WA resident who tows a travel trailer (Ibex by Forest River) with his AWD CT I applaud you and appreciate this write up!
