- Oct 3, 2020
- Western Washington, USA
You need to go pretty fine to get a mirror finish, past 1000 grit, probably to 4000 grit.The thing you need to be most careful of is being sure that you use the right grit. If you use one too low, you end up with nastier swirls. Use too high of one, you end up with a mirror finish. I thought I read in one of the Tesla service manuals that they recommended a particular grit. As someone said earlier, get a scrap piece of SS from HD and practice with different grits to find the magic one.
Scratch remover is ultra high grit… I would be careful of that as it’s made to bring a sheen back to clear coat. That will definitely give you a mirror finish.
I've found the most suitable grits for removing fine scratches and bringing the finish back to new condition is to start with 320 grit to get the fine scratches out, move to finer grits until you get the desired look. The factory grit looks to be around 500-800 grit (depending upon the type of sanding pad used).
Pro tip: The Tesla instructions say to use 1" overlap between strokes. At first I thought they meant your passes would only overlap 1". That does not give the desired result. Each pass should be offset about 1" from the last pass. To my way of thinking, I would call this a 5" overlap (if using a 6" sanding pad). This is required to get an even finish. Once I figured that out, it was easy to get beautiful results.
Also, don't bear down hard, a light touch is all it takes and your abrasive pads will last longer.
