Beast mode 100% of the time
Leifmb
Leif
2025 Cyberbeast
I suspect 11k miles is not the record for cb owners :)
I suspect NOT as I’ve never launched it and didn’t push it fully except briefly on on-ramps! I really was trying to be mild-spirited having had a Plaid X previously! I figure these original tires may last another month or two…UNLESS I decide to put it in Baja mode and do some donuts and launches 🚀 😀 🤔
Leifmb
Leif
2025 Cyberbeast
Yea I didn’t rotate so I could see exactly what the ware would be, at 20k miles fronts was down into the warebars. So I rotated and found standard has plenty of power but doesn’t eat the tires near as bad. Got 40k miles on my first set. On my second set now with 68k total miles so about 28k miles. I have rotated this set once. Need to again. 2300$ for an OEM AT set.
I rotated at 4300 and again at 11,000. Pretty even wear however the fronts take the brunt of it.
BenlovesCT
Ben
Langley BC Canada
Foundation Beast
FYI if you use custom you will lose launch mode. I set up my scroll wheel to switch between modes on my CB. FSD is so good I ride around in comfort/chill which is very comfortable and slap on Mad MAX and let the truck drive 90% of the time. But yes... Beast Mode is fun. It is also fun to switch into Beast mode because you can feel it hunker down and flex. Honestly Standard has enough punch to win stop light drag races. Baja high rough is also amazing off road IMO.
TLDR try them all. Setup the scroll wheel. The versatility is amazing.
Leifmb
Leif
2025 Cyberbeast
I DONT use comfort mode in FSD now and after I switched I did the usual stop sign “hurry up” press and it whipped me pretty good! I like having the power always there in case I “need” it! ✊
BeFamousVideo
Vincent
Orange County, CA
CT Beast delivered May 2024
Automation Agency
True statement, although I picked it up yesterday I expect this is the mode it will always be in. Any reason other than effeciency to mode other?
You can use Custom in dynamics to raise suspension when in Beast mode.
Enjoy the ride, after 20k miles Beast mode still is a thrill.
