Bed divider fitment issue
bkandy3
Andy
Thousand Oaks, CA
AWD Cybertruck
Just ordered this the other day and received it today. Same issue.
OP, did you ever get resolution?
Someone made cuts on the bottom frame of it on another thread, but that’s a bigger project than I’m willing to tackle.
I’m about to bend the ends down and risk it. I won’t ever want to keep it over the “smugglers bay.”
loki
localhost
Unfortunately not. Last service appointment they said Tesla is aware of the issue and will let me know once there is a path to resolution.
bkandy3
Andy
Thousand Oaks, CA
AWD Cybertruck
Yet they continue to sell these. ?
Seems to me, after an hour of battling just now, the bed isn’t consistent thinkness and must be thicker in the middle as compared to up by the gate or back by the cab. They would need to redesign the divider to have a little more clearance on the bottom. Everyone is going to want it just behind the latch for the bay.
loki
localhost
I agree. That’s where I want to keep it. Unfortunate haven’t heard anything still
Davepick
Austin
911, 66 Corvette, Range Rover, Miata, Mercedes
No amount of pushing, shoving or even sitting on would persuade mine to fit so i decided to return it as I don’t want to be stuck with something I can’t use.
bkandy3
Andy
Thousand Oaks, CA
AWD Cybertruck
I ended up cutting off the top quarter of the 4 plugs that go in the L track. I know it’s not max stability as it was intended, but I’m just using it to hold the cargo bins against the cab and have grocery hooks on it. It’s good enough to serve that purpose.
So frustrating though to have a Tesla $350 accessory not fit right.
I assume the divider design team probably isn’t happy with the bed lining thickness tolerance. Either the bed people didn’t hit their tolerance for consistency or the divider team didn’t account for the full range of tolerance.
loki
localhost
My service center knows me for having had so many issues and visits regarding the divider. When bringing it in for a recent service visit they mentioned I should contact Tesla to get a replacement with the adjustable feet. I know someone already posted they got it but was never “official” from Tesla. When I asked about it when that was posted they said only Tesla has official updates. This time they are sending me a free replacement after contacting them. Let’s hope it’s the updated one!
bosshog
roardog
canada
I have same issue. Havent sent it back yet but will .
. Did they indicate they sending you a replacement with adjustable feet as I was under the impression the new one has pads on the bottom and not adjustable
anyone know more about the replacement new One ?
loki
localhost
Commerce is sending me a replacement. Let’s see if it’s the “updated version”. I meant adjustable as in having the pads or not. Let’s hope it is!
bosshog
roardog
canada
Thanks let us know and if it solved the problem . I will wait until sending mine back at least put a request in for the new one .
CarMan ElecTruck
Other Earth
LeftFoot RightFoot
This will be my first accessory (if we disregard the SecondRow Pet Liner under the Tree). Should arrive tomorrow.
I hope it’s the revised version as well.
LiveFreeOrDieBob
Bob
New Hampshire
F150, Cyberbeast
Contact Center Consulting
I had this issue and it WAS fixed by the service center. I'm not sure how the new "adjustable feet" are going to help anything, because the issue wasn't with the feet hitting the bed floor, it was actually the bottom of the gate resting on top of the raised ribs of the bed floor across the whole width of the gate. The "feet" never even came close to hitting the floor.
What my service center did was to loosen all of the bolts that secure the side of the bed (and there are some that aren't obvious hidden in the floor and in the front) and then they adjusted the bed side and L-track up a tiny bit and re-tightened it. The divider now latches perfectly along the entire length of the bed. Before that, it would only latch above the rear storage compartment because the "ribs" of the storage compartment were a little bit shorter than the bed floor forward of the storage compartment.
I had tried loosening the bolts along the L-track and raising the L-track myself before taking it to the service center and that didn't work, but it was because there are a couple of bolts you can't see without removing other pieces that prevent you from raising the L-track and the sides of the bed. I THINK you can see all of the locations on this picture, but I'm not sure since I wasn't there when the tech fixed it.
Given what I know now, and the fact that we can get the repair manuals online, I would probably try and fix it myself if mine hadn't already been fixed by the tech at the SC.
BTW - my service associate INSISTED that there was no problem, and kept putting "could not reproduce" on my ticket even though I attached multiple photos of the L-track latches not lining up and the bottom of the gate sitting on the ribs of the bed floor. It wasn't until I insisted to talk to the service manager and literally showed him the problem that they acknowledged the issue, and then were able to fix it in about an hour. Since the SC is an hour away from my house, the fact that I had to drive down there and then sit around definitely was frustrating, but now that the divider works as designed I am super pleased with the purchase - totally worth it. I also bought some 3D printed Molle hooks to put along the top square holes of the divider, so when I go to the grocery store I put the divider 2' back from tail gate and then hook the grocery bags on the hooks and it prevents everything from sliding around no matter how I drive - very convenient!
Jack27
Randy
None
Great info. Exactly the rubber legs have zero to do with the problem ! That’s probably why when I tried to loosen just the 3 bolts in the L track I didn’t see anyway it could move up as it was already against the light.
in the photo they have the entire interior of the sail off ? Is that a necessary step? Because I don’t see anyway bolts in there circled ?
CarMan ElecTruck
Other Earth
LeftFoot RightFoot
Fresh in the box… I honestly don’t know what I’m looking at, but I think this has the revision based on the extra ‘spacer’ at the foot.
Tesla Cybertruck Bed divider fitment issue imag
Tesla Cybertruck Bed divider fitment issue image
bosshog
roardog
canada
Doe that fort have an adjustable foot . I was under the impression the revised one had that . Can’t really see in the photo . The foot doenst look adjustable …
