BEST EXTERIOR CLEANING AGENT
Garee
Gary
St Cloud, Florida
I was cleaning my cyber truck with little scrubby‘s, the fiber scrubby’s and I have scratches micro scratches. How do I get them out?
Non-woven pads, also known as "little scrubbies" come in two categories. A typical Scotchbrite pad has abrasives bonded to it, some are just the non-woven pad without abrasives. When doing simple cleaning, you always want to use the kind without abrasives so you don't impart a different scratch pattern.
You use a non-woven pad with abrasives to get scratches out but it does that by applying new scratches in a random pattern that gives the appearance you want. A 6" round, non-woven pad with abrasives of the right size on a random orbit sander can do that, it's nearly impossible to do it by hand, at least I don't know anyone who can. The random orbit sander can do it. Proper grit range is 400-800 grit if you want to maintain the factory appearance. These are often graded "fine" or "very fine" depending upon the manufacturer.
More detailed instructions can be found by searching this site.
