SD2012
Steve
Western NY
Model 3 AWD
Sad to say, I don't even know what Starlink does - or will do. GPS?
Gorgo1949
William
Chipley, FL
3 motor cybertruck
I would like to tow this behind a RV, so I'm hoping freewheeling will be a part of it
Planet Earth
Many say that we are now polluting the skies with space junk just like we have polluted the earth. Tons of articles on the subject.
Even the tiniest bits of space junk can cause damage
“At last count there were over 20,000 pieces of space junk larger than a softball, and about 500,000 larger than a marble orbiting Earth.
Scientists say there are many millions more too small to be seen and the number is growing all the time.
Even the tiniest fragments can cause damage — according to NASA flecks of paint led to a number of space shuttle windows having to be replaced.
It has even been suggested that at some stage the sheer number of bits of space junk will cause a "cascade" of collisions and could render an orbit unusable.“
Tesla Cybertruck Predictions for the top 3 Cybertruck exterior modifications 60947BFC-6B16-4935-A7F1-5E21CF46B2D3
maconjt
Jeff
Iowa
Hoping to be a Cybertruck owner.
FMEA Coordinator
Here are my predictions;
1) Aftermarket wheels and tires
2) Vehicle wrap
3) Paint factory wheels arches/flares
I'm not sure it will have paint options. The exoskeleton is dent proof and if you smack the side of it with something it will leave a mark of some sort. Unless they have scratch proof paint....lol.
Muskwatcher
Martin
Arkansas
Silverado 1500 LTZ Crewcab, Toyota Avalon
Military
Yes there is a lot of debris up there. The Starlink satellites are designed to de-orbit and burn up completely in the atmosphere when they lose the proper function. Elon Musk also talked about the de-orbiting starlink satellite functioning as a debris collector on the way down. This could solve a lot of the debris problem.
nomadmusk
Droxx
Civic to Cybertruck
2nd infantry of Tesla's Quality Division
I will be adding a electric tint to side windows and sun roof. Those who dont know, electric tint is where with flick of a switch, tint turns to opaque or transparent. I like to have glass transparent in winter so sun can keep the car warm and summer the glass stays opaque so sun don't heat it up. I installed it in my current F450 in 2017 and it works like a charm.
Can you tell me more about this install. Brand used and if there are any tutorial videos? I've been thinking about doing this modification for a while.
Must have mods:
- Additive solar ports
- Greatly increase the amp drain cap that's present in other teslas so we can use power strips.
- Mounting points for an automatic fronk winch would be a godsent for adventurers' backs and security worries (ooh even with a small fronk passthrough to winch things in-through the bed passthrough that would be wild)
Honorable mention:
a detailed blueprint highlighting all safe zones to put magnets or holes on the body for awnings, hooks, and other such camping stuff.
ElectricSheep
William
AZ
2019 Jeep Wrangler Unlimited Rubicon
Mechanical Engineering
Honestly my biggest concern once I get one is that idiots will want to hit the body to see if it takes damages and throw stuff at the windows. I fear the idiocy and lack of concern for damaging other peoples property.
Maybe a small Silent Guardian system that uses millimeter microwaves to keep them at bay. Probably need a second battery to support that.
ElectricSheep
William
AZ
I think we should send up a space magnet
Unfortunately most of the space junk is probably aluminum and other non-ferrous materials. The other issue is the space junk is probably not all rotating around the earth in the same general direction. It is a problem and you have to wonder how many Starlink satellites will be hit as objects orbits degrade over time.
CyberCop
Between San Antonio & Austin
Silverado HD , Cybertruck dual on order
Retired LEO ?‍♂??
The engineers at Tesla I’m sure can develop an aluminum magnet ? and or giant net similar to a swimming pool net and scoop up all the crap floating around. ?
cyberhunter
Heath
Since one of the top 3 things I see people wanting to mod for the CT is wheels, I have been thinking about that a bit and even posted some images of the CT with different wheels.
After watching several youtube videos, I realized that the wheels have a decent amount of effect on range on the model 3. There is enough effect on the aero based on the spoke design that it does have a legit effect. The best aero wheels would have a solid hubcap and Tesla has that near solid hubcap they put on the car for the long range model.
That is exactly what is on the CT in the prototype. Those are hubcaps right now and I bet that is the intent for the CT...to have that option much like the M3. I bet behind the hubcap is a pretty decent looking wheel just like what happens on the M3. That will be nice. We can just buy a $50 kit to put the hub and lug nut covers on it when you don't need extended range. When you go on long trips and that extra 5% range is needed, just put on those hubcaps. That's way better than having to buy a whole wheel set and sacrifice the range permanently.
ev4me
Kevin
Winter Garden, FL
Cybertruck (single motor)
Construction Estimator
-Modified 5th wheel adapter to clear side pillars
-Snow plow mount
-Transparent tonneau cover (for those who habitually need to physically look through the back window to reverse)
Bigfoot DeLorean
Chicago
Range Rover
Hmm...(only half serious)
1. bulk stainless polish
2. A Cyberladder made by tesla in the same theme and materials to help clean the car
3. DIY Clear wrap for nose and behind rear tires. I’m assuming the 3mm SS can get marked from gravel
4. 3rd party luxury seat
5. Tesla extension cords
6. Extended range battery for the vault
7. bulk wd40 for coating body in winter (it they dont have heated panels)
8. hvlp paint sprayers for DIY wraps
9. pet seat covers
10. 24/7 security video system (unless it does it already)
11. 5 point racing harness
Definitely NOT on the list...
- upgraded car stereo head unit
- touch up paint
- jumper cables (except for giving other people jumps)
side question - will the body be able to be certified as a roll cage? It’s quarter mile time may require it if you take it to the track.
