CYBERBRITE1
CYBERBRITE1
Gary
cyberbrite1.com
CYBERTRUCK
Added qty 3 to my cart and still see a shipping charge. Is there something I need to do for free shipping?
Hi am addressing that on the ordering platform ASAP. You will not be charged for shipping.
thanks
Gary
sharpgator
Scott
Birmingham, AL
26 AWD CT, M3
I want to make sure my plan is OK. I would apply this in my garage. Then drive to the carwash (20 minutes, likely in bright sun) to wash it off. Sound ok?
CYBERBRITE1
CYBERBRITE1
Gary
cyberbrite1.com
CYBERTRUCK
When you say 2 continuous coats, you meant apply, rinse it off, apply it again then rinse it off ?
or 2 coats at the same time then rinse it off ?
Hi. Do not rinse between applications. Start at a section, apply to entire truck then continue applying second coat over first application. Thanks for the heads up on this!! I will change instructions to reflect this specific application process.
Thanks
Gary​
CYBERBRITE1
CYBERBRITE1
Gary
cyberbrite1.com
CYBERTRUCK
Hi, yes that would be ok. I’ve actually done that myself.
Thanks
Gary
CYBERBRITE1
CYBERBRITE1
Gary
cyberbrite1.com
CYBERTRUCK
Hi, it shouldn’t be a problem. I will check with shipping and respond to you here ASAP. Thanks for the heads up on this!
Gary
Hi I’ve check with shipping and the regulatory issues among other transactional concerns will need legal guidance. We are just beginning this and unfortunately will only be able to sale in the United States. As we grow and learn, we will be offering in Canada. We will change our website to reflect US sales only. This issue will be high on our list as we grow. Sincere thanks for your interest!
Thanks
Gary
That Beast Mode
Phil
New Jersey
So, I have a quick update for all of you wanting to see some results from this stuff. First off, disclaimer, I am not affiliated with Cyberbrite in any way, not a YouTuber or blogger, etc. Just a guy who owns a cybertruck and likes trying out new stuff. I was however sent this bottle as a sample to try but after testing it I went on their website to purchase another one with my own money for that introductory promo - I am just waiting for them to fix the shipping charge issue on their site they mentioned.
So, I received the Cyberbrite today and was curious to try it, so far the test results look very promising. It is still too cold here in NJ to wash the truck so I did a roughly 2 ft x 2 ft section just as a test until it's warm enough that I can clean the whole truck - it's filthy. Here is what I did, which wasn't much. I wiped a roughly 3 ft section down (to make sure the soap didn't have the same results) with a wet, lightly soapy rag, rinsed it off and dried it. I only applied a single coat of cyberbrite to saturate the area, waited 15 minutes and rinsed it with water and dried it. See the pic for the result. It was dark out when I took the pic, but you get the idea and it looks much better in person. I'll update whenever I have a chance to do the whole truck. My plan is to ceramic coat it after using this stuff on the whole truck so we'll see how everything holds up long term. I've never used Citrisuf to know if it gives a similar result, only BKF so thats all I can compare it to. From my little test area it did a great job with 1/10th of the effort.
Top right is where I applied it, in the square shiny area.
Tesla Cybertruck CYBERBRITE--Cybertruck De-staining and Passivation Solution (REDUCED INTRODUCTION PRICE $23.95) 20260321_203114
resellpanda88
NY
Cyber Truck
Can I use this to clean my truck then if I decide to wrap it a day or a month later can do so without any negative effect?
I know if I ceramic coat my truck I am unable to wrap it because it would not bond with the ceramic coating.
CYBERBRITE1
CYBERBRITE1
Gary
cyberbrite1.com
CYBERTRUCK
Just placed an order for 3! Will this stuff work on stainless steel appliances as well?
Hi, CYBERBRITE is formulated for Cybertrucks only. I have only used it on my truck. Having said that, I can't stop people from using it or diluting it 50% with distilled water to see what it does to stainless appliances. Not a recommendation!!
Thanks,
Gary
CYBERBRITE1
CYBERBRITE1
Gary
cyberbrite1.com
CYBERTRUCK
The CYBERBRITE treatment leaves passivated bare stainless steel with no contaminants. In my industry, there are products that have coatings that are similar to wrap. Stainless steel products that are coated that have not been de-stained and passivated will develop tiny corrosion spots under the coating over an extended time that only show up as rough spots on the covering. It's my opinion, based on 35 years of experience, that wrapping Cybertrucks that have not been thoroughly decontaminated could possibly develop tiny damaging rust spots under the wrap. I have know knowledge of how business that wrap Cybertrucks prep them before wrapping. Im sure they address this issue. This is new territory because Cybertrucks have not been around long enough to reveal possible problems in the wrap overlay. If I decided to wrap my truck, I would definitely treat it with CYBERBRITE the day of wrapping, if possible, to have the cleanest possible surface. The passivation will have no effect on wrap adherence.
Thanks,
Gary
Sposborn
Indiana
2024 Cybertruck AWD; 2025 Model Y Performance
I am sorry if this was answered and I missed it but am I able to apply this and potentially wrap over it?
