CYBERBRITE Understanding the properties of Cybertrucks stainless steel exoskeleton
CYBERBRITE1
Gary
cyberbrite1.com
CYBERTRUCK
The Cybertruck’s exoskeleton is made from an ultra-hard 30X-series stainless steel alloy chosen for its exceptional strength and corrosion resistance. Unlike painted vehicles, its protective properties come from a thin, invisible chromium oxide layer (called the passive layer) that forms naturally on the surface when exposed to oxygen. This layer acts as a barrier, helping prevent the underlying metal from rusting.
Natural passivation begins almost immediately upon exposure to air, but the initial layer is very thin. Environmental factors—such as high-speed impact of road debris, iron particles from brake dust or rail dust, road salt, bird droppings, and other contaminants—can disrupt this layer or leave microscopic particles that cause visible staining and discoloration. In most cases, these spots are surface contaminants oxidizing rather than deep corrosion of the stainless steel itself.
The beauty of the stainless steel is its clean, raw, bright silver finish. When the stainless steel is thoroughly cleaned of contaminants and properly passivated, it returns to its natural bright appearance and maintains strong corrosion resistance. However, like any bare metal surface, regular washing is still recommended to prevent buildup of new contaminants—especially after exposure to road salt, bugs, or industrial fallout. Regular washing and prompt removal of corrosive substances (as recommended in the Tesla owner’s manual) help maintain its appearance and resistance.
CYBERBRITE is a dual-action formula specifically blended for the Cybertruck’s 30XX-series stainless steel. When properly applied, it helps remove surface oxidation and quickly builds a more durable protective nano-layer that can reduce re-contamination for 4–6 months, depending on environmental conditions.
Best Regards,
Gary
LexusCyber
Marius
Redmond, WA, USA
Lexus LS460 AWD V8
when I get my CT I will try Cyberbrite to keep it looking great...unless I wrap it in some out of this world pattern :)
quick Q: if I polish the CT - I've seen some CT owners with the mirror polished look - can i still use Cyberbrite to keep it lookin great?
CYBERBRITE1
CYBERBRITE1
Gary
cyberbrite1.com
CYBERTRUCK
CYBERBRITE will work on all stainless steel finishes. Carefully consider the laws regarding mirror finished vehicles. Some states may have restrictions.
Gary
