- Gus
- May 22, 2021
- Austin, TX
- 1981 DeLorean, 2024 Cybertruck
- IT Specialist
For clarity, Teslas do not have "steer-by-wire". The computer can turn the steering without user input via an electric actuator, but the physical linkage remains intact at all times.Current Tesla vehicles already have steer by wire, it just works in conjunction with steer by mechanical linkage. And they (presumably) power that function with a 12V 500Wh battery. I don't see full steer by wire using much more (if any) power than the current system. Unless your argument is less about steer by wire, and more about having 4 wheel steering, which would require more power.
"The SbW system electronically transmits the driver’s steering input to the steering actuator assembly. During normal operation, SbW systems do not have a mechanical connection between the driver and the front-wheels."
https://www.nhtsa.gov/sites/nhtsa.gov/files/documents/13502_812576_steerbywire.pdfI believe the correct terminology would be "autosteer".
