- JB
- Nov 22, 2019
- Australia
- Cybertruck
- . Professional Hobbyist
But , but, but... I'm not until proven otherwise?JBee, you're just wrong on this.
Just like most computers don't use 12v anymore, neither will the Cybertruck.
So this is a motherboard main connector pinout:
I see all the voltages I mentioned: 3V, 5V and 12V. Multiple circuits of each even.
Even the high power CPU and GPU supply connectors are still 12V:
The 12V power that comes onto the motherboard is then sent to the VRM modules on the motherboard, right next to the CPU to avoid further losses and to ensure CPU stability. They convert the 12V supply from the PSU into the CPU voltages around 1-1.5V onboard the motherboard. An 8 pin CPU/GPU plug can supply up to 670W each, if your PSU can deliver it.
The point here is that the lower the voltage the shorter the distance you should have to reduce excessive amounts of extra copper to handle the current.
I also included "MCU" in that post which is the "MicroController Unit". These are all the distributed controllers though out the system, and they all run on 3.3V. There is exactly zero versions that run directly on 48V, because most of the logic peripherals on the PCBs run 5/3.3V as well. Things like sensors etc.
Now the MCU's normally run on less than 1-2W, so having them on 3V is still only 0.5A, so you don't need a big cable even if they are far away, in fact a LAN cable would be overkill to power them in a car. But the CPU can be pulling a few hundred watts when it's cranking FSD with the GPU, and the GPU would pull another few hundred watts as well and all the components need 12/5/3V as above, and given their power levels AND SHORT cable lengths can easily be run on those lower voltages with negligible losses or large cable requirements.
The main CPU/GPU unit will of course be nearby to other high energy peripherals in the dash/forward firewall area. A such you'd have a high voltage feed coming from the main battery, that is then converted to 48V for the air-conditioning compressor, power steering, brake amplifier, air compressor etc. It would also have a 12V conversion there for the PC gear, and all the rest of the stuff on 12V, like the LCD, ventilation fans etc that all only need a few hundred watts or less.
Remember: Cable resistance is the result of the ohmic resistance of a cable OVER a length. That means if you make it shorter, you don't need a bigger cable to transport the current efficiently. So a cable that has half the length, also has half the resistance. Agreed?The wiring harnesses are long. That itself makes it worthwhile, even if the loads are only a few watts. Munro has lists, if you want. But both Tesla and Ford have talked about how much it would save them in weight and copper. It was considerable.
If so then a single large power "bus" along with shorter smaller feeders, works out much better than a seperate cable from each consumer running back to the fuse box and relays. Regardless of the voltage used. This is what I meant with the statement that the bus architecture is more important than the voltage. But of course the higher voltage also helps, but only for the higher energy consumption devices and not all the little bits and bobs that can continue to run on a lower voltage. It's actually harder to run all the lower power stuff off a 48V, because you'd have to get it down to 5/3V for running electronics on the line.
Then there is of course the lighting system of the vehicle, but there are already many manufactures that use CAN bus to controll a light MCU in the light fitting, which in turn switches individual lower power LED lights. Of all things, the lights are probably the best fit for the 100W or so power capacity of a 48V PoE LAN.
This is also a question of what MCUs you use. Many automotive rated MCU's already have CAN built in, meaning they don't need to have a router to connect to other devices on the network, as they can all address themselves and share cable timing. Each Ethernet node costs extra, plus you need to route point to point to a router. WIth CAN you can just loop one cable through all devices and even back to the original device without a router or single point of failure device. That way you can break the loop anywhere and they can still communicate via the other side of the loop.Compatibility with PoE style components makes it all the better and repair easier.
Now for cameras they already have dedicated inputs direct to the mainboard, so these would likely be running at the camera voltages 5/3V as well, and you don't want them being bottlenecked through a router setup with other lower priority traffic on the same Ethernet bus.
Given the above, just how much "other stuff" needs a 48V supply?
Please do tell. Hence my proposal that people should make a list and think about it a little bit.
