Cybertruck Screen Swivel Mount: A Tailored Upgrade for Owners
Tesstudio
Tesstudio
www.tesstudio.com
Dear Cybertruck Owners, greetings! As a brand dedicated to developing Cybertruck in-vehicle accessories, Tesstudio has always focused on "aligning with the original vehicle's characteristics and solving practical needs". Today, we officially introduce our flagship product - the Cybertruck Screen Swivel Mount. From design to mass production, this mount has been refined around the usage scenarios of Cybertruck owners, and the following core advantages are the key to its recognition by many owners:
First, 1:1 restoration of the original factory screen height is our core design principle. We understand that Cybertruck's interior layout is calculated through precise ergonomics, so we firmly avoided the compromise of "lowering the screen height" during R&D. After the mount is installed, the screen always remains in the position set by the original factory. Whether you check navigation, operate the infotainment system while driving, or use it daily, you don't need to adjust your line of sight habits, completely eliminating safety risks caused by view deviation. At the same time, it perfectly fits the minimalist interior style of the original vehicle without any sense of disharmony.
Second, military-grade materials and structure lay a solid foundation. The main body of the mount is made of aircraft-grade aluminum integrated molding, which is not only light in weight and high in strength, but also can effectively resist wear and corrosion during long-term use. Equipped with a dual-axis damping structure design, it has been verified through multiple off-road road tests - even on bumpy unpaved roads, the screen can remain stable without shaking or abnormal noise, completely eliminating the pain point of "looseness and easy deformation" of traditional plastic mounts, and providing long-term protection for the screen.
Third, tool-free and damage-free installation, easy for anyone to operate. We fully consider the owners' demand for independent installation. The mount adopts a modular splicing structure, no drilling or disassembly of original vehicle parts is required. You only need to follow the instructions, and the installation can be completed in 3 minutes, with zero damage to the original vehicle structure throughout the process. After installation, the fit with the screen and interior is as high as 99%, and the delicate chamfering treatment at the edges can also avoid scratching the screen or interior, showing ingenuity in details.
Finally, flexible multi-angle adjustment covers all scenario needs. The mount supports 40° horizontal swivel and 20° vertical tilt adjustment. Whether it is the optimal viewing angle for the driver to focus on navigation, the comfortable angle for the front passenger to watch dramas, or the need for rear passengers to use the screen after parking, it can be easily satisfied with a gentle adjustment. The damping feeling is uniform during adjustment, the angle positioning is accurate, and it is fixed as soon as you let go, no need for repeated adjustments.
From design to launch, this mount has always taken the real needs of Cybertruck owners as the starting point. If you are looking for a solution that "does not damage the original vehicle experience but can improve the practicality of the screen", it will be your ideal choice. In the future, we will continue to collect owners' feedback and create more high-quality accessories for Cybertruck. Thank you for your support!
Buy Link:https://www.tesstudio.com/products/...2&_sid=d7807eb34&_ss=r&variant=51628763513121
jditom
Oregon
2026 Y 2025 CT AWD
I just ordered one and was very impressed with there V2 model Y screen that did not lower it. Which has always been my biggest complaints of the tilt screen world. If anything being able to raise the height for tall folks would be even better. Someday????
hbutler
San Jose
CyberTruck
Does this push the screen out further away from the dash? I get the height doesn’t change, is the screen pushed out away from the dash as a result of not impacting the height? How is room made to allow for the swivel
Tesstudio
Tesstudio
Tesstudio
www.tesstudio.com
The height remains unchanged, and the angle can be adjusted according to your needs
Incredibly cool advancement. Probably not ideal for my specific use case but I can see how this will be a huge improvement for a lot of Cybertruck owners. Well done.
hbutler
San Jose
CyberTruck
Sorry. That doesn’t answer myunderstand the height doesn’t change, but does extend further from the dash that oem setup. How do u create the room for it to swivel.
Gavinbee
Toronto
Cybertruck Beast, 2020 MYP, 2023 MXP
I also have the same question @Tesstudio, does the depth change with this mount (ie. v3)?
Gavinbee
Toronto
I haven't purchased yet. I would say this is more pre-sales discovery.
Tesstudio
Tesstudio
Tesstudio
www.tesstudio.com
Tesstudio
Tesstudio
Tesstudio
www.tesstudio.com
Compared to OEM, is it the same height and depth or just the same height ?
Depending on the depth, a little bit will come out.
