CYBERTRUCKco
Roger
Poway, CA
manufacturing
https://cybertruckco.com/product-category/cybertruckco/
Guys,
Happy Friday! Wanted to share this before the weekend started for all you guys getting on the trail - you need this!
Introducing our new CYBERTRUCKco Lift Rod Kit, the perfect "upgrade" for Cybertruck owners looking to "elevate" their vehicle’s ride height without breaking the bank.
The kit replaces the original lift rods, tricking the suspension system to increase the air in the shocks. We took this concept from the Land Rover lift rods we have made off an on since 2004, so nothing new for air suspension.
We used aircraft-quality black anodized aluminum, with high temp, chemical resistant grommets, so the Lift Rod Kit is designed to withstand everything thats going to be thrown at it from daily driving and challenging terrains.
The front rods are easy to install and can be done with the vehicle in high mode and the car turned off. The rear rods require you to remove the rear wheel and swap them out, thought you may be able to crawl under the rig, just not recommended...
They have a linear lift from 1" at Low, 1.25" at med and 2.125″ of lift in high mode. We noticed no difference in ride quality, or mileage loss in Low and medium on the road. The Cybertruck rides higher in all settings, the higher stance = looks great and added ground clearance for off-road trails.
bets of all the $79.95 kit is available now and $9,940 less than some way off in the distance 2" lift + labor. We think this is the right kit for 99.9% of CT owners who want lift.
First 20 orders this weekend will get an $25 coupon to use in the store for your next purchase.
Let us know what you think, and have great weekend!
Tesla Cybertruck CYBERTRUCKco 1-2" Lift Rod Kits available now - $79.95 lift kit! cybertruckco-cybertruck-222-lift-rod-kit-1
Tesla Cybertruck CYBERTRUCKco 1-2" Lift Rod Kits available now - $79.95 lift kit! tempImageHoadKq
Tesla Cybertruck CYBERTRUCKco 1-2" Lift Rod Kits available now - $79.95 lift kit! tempImageMMT7sK
Tesla Cybertruck CYBERTRUCKco 1-2" Lift Rod Kits available now - $79.95 lift kit! tempImage5rGzVF
Tesla Cybertruck CYBERTRUCKco 1-2" Lift Rod Kits available now - $79.95 lift kit! tempImagescIZu3
Tesla Cybertruck CYBERTRUCKco 1-2" Lift Rod Kits available now - $79.95 lift kit! tempImage4tTZQr
Tesla Cybertruck CYBERTRUCKco 1-2" Lift Rod Kits available now - $79.95 lift kit! tempImageGmnC7U
Tesla Cybertruck CYBERTRUCKco 1-2" Lift Rod Kits available now - $79.95 lift kit! tempImageDJsG60
Tesla Cybertruck CYBERTRUCKco 1-2" Lift Rod Kits available now - $79.95 lift kit! tempImagetUtR9S
Tesla Cybertruck CYBERTRUCKco 1-2" Lift Rod Kits available now - $79.95 lift kit! tempImage4ZXr4t
Mettalicron
Utah
Model X, Cybertruck
Software Engineer / Business Owner
@CYBERTRUCKco This is cool, im VERY interested, but concerned about stability in the very high and extract modes, how do those perform and are there any gains in height there? I offroad semi difficult terrains around once a month in my CT so this could be a home run for me.
steveanderson3
Steve
Kansas
2 Tesla Model Y's
Is there not a way to variably adjust the air suspension right now? I don’t have a CT yet so just asking. Are there presets for suspension height that you cannot adjust and this just adds a little bit to each of those?
Deleted member 17810
Guest
Someone has some explaining to do. I KNOW I’m from Louisiana and might be dumb, but how does CYBERTRUCKco lift a CT for $80.00 and UNPLUGGED does the same for $10,000?
What am I missing?? I’m sure it’s obvious.
One is a whole suspension.
The other appears to move a sensor.
Shodan01
Upstate SC
CyberTruck Dual
Im assuming this is similar to the range rover lift levers that essentially trick the air suspension to thinking its normal when it is in medium etc. When I had those I couldnt tell a ride difference etc. Is this the same concept?
BannedByTMC
NYS
Roger@CYBERTRUCKco
Roger
Poway, CA
manufacturing
We ran all of the modes on Oraflame Canyon, which is a pretty technical trail for the Cybertruck with some good obstacles that needed them and had no issues. The shocks also top out so extract mode is no taller than it normally is
Roger@CYBERTRUCKco
Roger
Poway, CA
manufacturing
Yes, exactly same concept. If you only run the front rods it also levels out the vehicle so it doesn’t let have the rake.
we also have another design that raise a little higher, but it needs the offroad testing before we can sell it.
Roger@CYBERTRUCKco
Roger
Poway, CA
manufacturing
It’s likely the dealer can do this, i’m sure that some electronics company will be working on this soon as well, probably in the $800-1000 range.
Ours is the most cost effective way to get a lift done in 30min.
MyFirstElectricTesla
SoCal
Benz
I'm an idiot.
Extract mode, put my head between the wheel well and front tire to check and still have no idea where to put these on and how they work.
Will these raise 2.125" in "Off Road" "High"?
Merle
Lake Tahoe
MS, 4Runner, Tundra, Lexus, R1200GSA, KTM, etc.
Do you have something like this to RAISE the MS (with air suspension of course)
Tahoe… snow basically.
On other vehicles of mine, we’d just tweak the adjustment bits. But this picture looks like it is slightly different, but just a drop in replacement.
Merle
Lake Tahoe
