Freemarket
Southwest
Stay at home Daddy
I know, the point I'm making is they should sell a set of fronts that is a bit shorter for those that are looking to level the truck (i.e. neutralize the factory positive rake angle).
Understood. I agree. I did actually expect the front to level it, but it does squat the rear.
Hknight54
Hugh
TX
So I bought the Lift Rod kit, at only $80 for the full set of 4 it was an easy decision. Why? I don’t like how the front nose sits lower than the rear end of the truck. It may be for aerodynamics, but I don’t care. I wanted it higher in the front. With that I didn’t install the rear pair, and did the front only. The results speak for themselves. In entry/low mode as shown in the photo it now sits basically level. Install was super easy, took seriously 2 minutes per side.
According to @CYBERTRUCKco at stock height, the front sits in low mode at 37.125” and the rear at 37.825”. With this kit installed in the front only, the front end now sits 1” taller at 38.125” making it just slightly higher than the stock rear height. Exactly what I was looking for. I did this for aesthetics only and this was a quick and easy solution. Highly recommend if you want the same look.
Here’s link to buy: https://cybertruckco.com/product/cybertruckco-lift-rod-kit-raises-truck-625-2-height-over-stock/
What does it do in extract mode? Is it safe at that height?
