FSD 14.2.2.5 - Dynamics changing to Comfort Question
TeslaKen
Ken
Overland Park
www.halocybertruck.com
Currently Occupied
After installing I notice that whenever I use FSD (always set to Hurry) and then come off of FSD if I go into Dynamics the truck is set to Comfort, not to Custom the way I normally would drive the truck around. Is there some setting that changes Dynamics when you are On FSD vs not on FSD? If this cannot be controlled, then are the rest of you seeing this?
I wouldn't mind if it set the Dynamics to comfort while FSD was in use as long as it returned Dynamics to my preferred setting (which is Custom) after FSD was disengaged.
I'm just wondering what the rest of you are experiencing or if you've checked your Dynamics settings while on FSD and after.
DanK
Clare
Mojave Desert
AWD Cybertruck
Mine switches from Comfort on FSD to Sport when not on FSD.
TeslaKen
TeslaKen
Ken
Overland Park
Currently Occupied
Ok so the switching to comfort seems to be normal, but switching back to whatever was set prior to FSD seems to be the issue I am having. I guess I will try a reboot and see what happens. Thanks for the responses!
