HELP: Can my Cybertruck tow for 144 miles without charging stops?
hectorcal
Hector
The Woodlands, TX
Hi there, I’m planning a 144-mile trip without any charging stops available. Will my Cybertruck be able to make it? It’s a 12x6 foot U-Haul trailer that’s almost full with clothes. By the way, the trip planner shows kilometers since I’m currently in Mexico. The trip planner shows 42% left, obviously without the trailer.
Tesla Cybertruck HELP: Can my Cybertruck tow for 144 miles without charging stops? IMG_1952
MyOtherTruck
Vermont
2020 G63, 2022 V60 Polestar, Ford F250HD, Cybrtrck
Only one way to tell! I'd bet yes tho if you take it easy on the throttle.
CT_AZ_4x4
Jay
Scottsdale, AZ
AWD CT
Self employed
Any RV resorts along that route? They almost always have 30 or 50 amp plugs.
RV parks have 30 and 50 amp plugs if you brought your mobile charger cable. Here are some in Nuevo Leónn area:
https://sanidumps.com/nuevo-leonn-rv-campgrounds/
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
I made it 175 miles towing on a full charge with left over range. My camper is 3200lbs and about 10ft high.
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
earthworm
S, X
I've found the range estimates not quite accurate with the trip planner in the car.
You can compute this yourself:
123kwh battery / 144 miles = 854 wh/mi
If you charge to 100% then as long as you stay under 854 wh/mi you'll make it. Take it up to 65mph and see what your efficiency is after a mile. If it's too much energy being used, reduce your speed to 60 or 55mph.
electricAK
Haines, Alaska
Cybertruck dual-motor
Use the energy app to track your progress along the way. It will update your arrival state of charge in real time as you drive. If it looks like you're not going to make it, you can slow down to save a lot of energy. 144 miles seems doable if your speed is low enough and its not uphill or bad weather.
aeroguy
VA
I use 115kWh for rated capacity planning - 319mi*361wh/mi. So, keep it under 800 wh/mi and you’ll be fine on a calm warm day.
Towing a 2-horse steel trailer (about 7k loaded) I average ~740wh/mi at 55mph and ~680wh/mi at slower speeds (30-40mph). Definitely doable, but you’ll need to be diligent on the 100% precharge, precondition, and watch your speed, especially if it’s cold out.
hectorcal
Hector
The Woodlands, TX
Definitely, I’ll be towing much less than two horses. I’ll keep my speed below 55 mph. Thank you!
Bobo_LaDouche
Carson City, Nevada
Cybertruck, Model 3
Reset Trip B, and watch power usage as you drive to see your actual rate; remain under 850 kw-h/mi. If you run low, you can slow all the way to 35 mph for best efficiency.
I plotted power usage vs trailer weight and velocity for about 20 members that reported this in the trailer section of the forum. I expect you will use 700 kw-hr/ mile or less while driving at 65 mph. Please confirm while driving...)
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
50 PSI or slightly higher? The Cybertruck Owner's Manual says to inflate all four tires to 65 psi when towing.
That's another thing, I inflated all the tires to 60psi.
FlykidCT
Jon
2024 Cybertruck
Pilot
I’ve pulled a trailer a few times with the CT and the number one factor in energy consumption is speed. I start off at 55 mph and let the truck learn the trailer and air loads it will pretty quickly revise the arrival estimates. Then maybe bump the speed up if there is plenty of margin but with no bailout options I’d be pretty reluctant to do that until more than half way through
