Hitch?
maconjt
Jeff
Iowa
Hoping to be a Cybertruck owner.
FMEA Coordinator
Not sure if anyone has discussed this, but I haven't seen a hitch on any of the pictures. Curious to know if this will be standard equipment or optional. I'm guessing standard due to most hitch manufacturers not having specs for mounting one. Also, will there be a "tow/haul" button. I'm purchasing the single motor and it's rated for 7500+ supposedly. I called a dealer to make sure it could tow a pontoon with that and they said easily.
beeeasybro
Quinn
Alexandria
Avalon,Outback, and previously Grand Cherokee
Boat Captain
I was wondering the same thing!! Where’s the Hitch??
Bigvbear
Justin
Eugene, OR
ts.la
The only time we have seen the receiver is when it was at the Petersen museum (pic below) I am thinking this will not be standard equipment but will be optional like on other teslas. Based on the pic it appears there is a removable panel in the plastic which would indicate to me it's not intended to be on every models by default. The hitch receiver itself is a removable unit
Tesla Cybertruck Hitch? Tesla-Cybertruck-Petersen-Automotive-Museum-Underbody
Tesla Cybertruck Hitch? Tesla-Cybertruck-Petersen-Automotive-Museum-2_1024x1024
maconjt
Jeff
Iowa
FMEA Coordinator
Interesting....haven't seen that pic. Thanks for sharing!
rjo71342
ray
melbourne,australia
current:outlander phev, next:cybertruck
custtomer service
i think based on the top amount that can be towed looking at a 2.5in or 60mm receiver would be the best option for starters based on this https://www.curtmfg.com/part/15810 to make sure i can tow more than rated
Diehard
D
U.S.A.
It looks like in this design, Tesla is giving priority to departure angle (28 degrees). TRX is 23.5 and Raptor 23.0. Elon has a Baja state of mind.
This could be a good survey. How many people would have the hitch permanently.
Model X setup tow rating is 5000 Ib. With CT3 tow rating of 14000 lb, we have to see if CT will use the same type of setup only more beefed-up or something more permanent.
If you remember something was used before. I just can't tell from this video, if the setup is te same as the one in show room photos or Model X:
Side note: With this jab at F150, and Elon trying to steal Ford's lunch money, if lightening reveals capabilities and features that makes CT less of a compelling choice (HUGE IF), that may add another "month or so" to CT update reveal while Tesla adjust the finished design. Lets hope lightening is good but not great.
Washington State
Given that the maximum tow capacity of the Tri-motor is 14,000 lbs, and the maximum capacity of a weight distributing Class IV hitch is also 14,000 lbs, I would assume this is what the Cybertruck will be equipped with.
So it will be the more popular 2" receiver with wide compatibility. A Class V hitch is really a commercial hitch and very special purpose in that most accessories and balls available won't fit a 2 1/2" receiver.
