How to drive in Low suspension setting?
MyFirstElectricTesla
SoCal
Benz
The default is always back to medium on freeway, how to bypass it to keep it in Low?
ChiTownCT
OG Rivet Crew
Chicago
CYBERTRUCK
Try the custom dynamic setting.. Lets you choose lower or higher
SoCal
Benz
heems
2023 Model Y AWD, 2024 Cybertruck FS AWD
My dynamics are set to sport and it rides in low all the time.
dalton108
Dalton
Lawyer
Yeah, that’s why I asked him if he had a beast I don’t know what you guys do in the AWD’s, but CB “Beast Mode” drives around in low and unless I’m off road that’s the dynamic setting you’ll find me in.
It makes sense that it would be a sport mode on AWD. So, OP why can’t you just put your vehicle in sport or beast mode?
btcrealm
Brian
Virginia-ish, USA
btcrealm.com
NOC
The more 'sporty' the mode the lower it should go. Whatever your performance mode is should be driving in low. Also if you set everything to performance and low in custom it should be driving low.
With the cyberbeast in beast mode it is always driving in low.
The lowest driving mode has about 8.4"-8.5" of ground clearance. That is also the "normal" driving mode at all speeds. The only lower mode is "Easy Entry" which is handy for loading heavy items or people with limited mobility, but it is too low for driving comfortably (or safely) so the truck raises back up to around 8.5" as soon as you put it into drive.
If you want to drive in a higher mode, you can select that in driving dynamics (select Prefer Higher). It won't corner as well (there is more body roll) but it's handy if you think you might need the additional clearance.
It will go considerably higher than that if you put it in Off-Road Mode (where you will have multiple higher modes available) but the highest modes are limited by speed.
Black306
Sacramento
‘26 PAWD CT | ‘23 M3 RWD
Lasttoy
Paul
St Augustine, FL
I take it u have read the owners manual? And don't understand it??
