How to install 12 volt accessories?
LuvOrH8
San Diego, CA
Cyber Truck
Anyone tried to install some 12v accessories? If so how do you do it, guessing there has to be 12v options available within the 48v architecture? Like I know there is the light bar pig tail, but is that pulling 48v or 12v? Do I need to hook up some sort of voltage transformer?
XQUIZIT
Lenny
New Jersey
Cybertruck, Tesla Model X, Porsche Panamera Turbo
Self employed
There are two power feeds:
  • One power feed is located on the roof (400W maximum draw).
  • One power feed is located in the powered frunk (400W maximum draw).
both are 48V and need a step down converter.
LuvOrH8
LuvOrH8
San Diego, CA
Cyber Truck
Thanks that was the piece of info I was looking for the step down converter. Easy enough.
XQUIZIT
Lenny
New Jersey
Self employed
There are actually many more power feeds, you've got to stop thinking legacy style.
There are nuerous USB-C ports in the vehicle that can provide several options of voltage between 5 and 18V. Any specific voltage can be provided by one of the many adapters available on Amazon.
RollingRefrigerator
Eric
San Jose, CA
Foundation AWD CT, M3P, MYP
For certain installations you need a regulator.
48V Step Down to DC 12V
This is the right answer. Low cost solutions exist for everything less hungry than winches and large car audio amps. If you find a low cost solution that is 100A+ capable, both the car audio and off road communities want to hear from you!
Lasttoy
Paul
St Augustine, FL
Take out front trunk. There is 48v outlet. Get a 48v to 12v step down transformer off ebay. Then u are able to install 12v stuff.
No room on roof to put converter
rlhamil
Richard
Glen Burnie, Maryland
Search Amazon for
120v to 12v converter 15 amp
That will provide pretty good 12VDC power using one 120V outlet. If you have multiple relatively low power gadgets, a 12V power strip (one plug, multiple sockets) could probably run them all off of that; just add up the amps to check.
I also see one that's 30 amp out, and one (with wire connectors, no socket) that's 50 amp.
The power will of course not be on all the time, only when the AC outlet is on; you can set it to be on all the time, but that will run down your battery faster.
I don't think that there is a plug, it's a set of bare wires hanging behind the front plastics.
Lasttoy
Paul
St Augustine, FL
Yes. One positive. One negative
Ck with volt meter. I forgot color code
