How to keep ride height?
T35L4
New Jersey
I've been driving on snow/salted roads for a week. Can't figure out how to keep the ride height on medium without it switching to low. I understand the high ride height reverts after 25MPH but does it have to change when you set it to medium? I find that it also reverts to low in many scenarios even without driving too fast.
T35L4
T35L4
New Jersey
Im actually driving around in urban environments and only want to raise the height so the salt isnt kicked up as much on the body. Not sure how effective it will be but any downside to using offroad mode in this scenario?
Tfran1521
i would say you could try it. a few notes though.
you have to turn on off road mode BEFORE you start your drive, cant do it while driving
Overland mode while keep you in HIGH ride height and ive been up to 65-68 for a short time but normally stay 50 and below without it lowering. ive noticed that it uses the front motors more in this mode. it shows you on the graph
Baja mode - while in SMOOTH it will keep you at medium height at whatever speed you want. ive noticed here that when at a stop you will need to keep your foot on the brake or it will roll if there's any incline/decline
you can change the power distribution while in baja so you could leave it at 50/50
Baja mode while in Rugged will keep the ride height in HIGH
now if off road mode is too much the only thing i can think of is on the normal drive mode set your preference to Higher and stay around and below 60mph
also, while you have to turn on off road mode while in park, you CAN turn it off while driving.
Limes2
Chicagoland
2025 Cybertruck AWD
Is FSD available in Overland and Baja mode? I haven't used the off road modes much and kinda sad that FSD does most of my driving now (over 95% since v14.2) since it's so much fun to drive manually.
CyberWalrus
FL
CYBERTRUCK
Is there a way to keep in medium and also chill mode for single motor efficiency?
Tfran1521
No FSD in off-road mode
