BUlldogtrix
Kevin
Candler nc
Ford excursion. Ford F-250. Dodge Ram 1500
Freight transportation engineer
Ordered one. Went to get installed. They couldn’t find it. Said would call me back when arrived. Two months ago
Mattkalin
Matt
SW Michigan
2023 F350 Superduty , 2023 Model Y AWD
I just want to buy the cover… I already got a spare!
jf64k
Ok how can tou confirm the bolt torque with a Lug Wrench??
Quick and dirty method (that assumes the lugs were correctly torqued and that you put the same lug nut back on the same stud it was removed from): Mark the lugs/studs with a sharpie prior to loosening them. When you’re tightening the lug nuts down, realign the marks.
Nidavellir
AWD CyberTruck
Contradicting about setting the ride height before putting CyberTruck in jack mode. In the video it says to set ride height to very high before entering jack mode, however, the CyberTruck manual says set ride height to medium before entering jack mode. Does anyone know which is the proper height to select before going into jack mode?
Trekboy
Redding, CA USA
Tesla Model 3, Cybertruck
I would imagine the lowest setting possible to create enough space for the jack to be placed in the correct position. Assuming there was also space to remove and install the tire around the fender flares.
pricedm
Adam
Denver, Colorado, USA
This is the excuse you're looking for to buy the correct tool for the job! Lots of decent quality torque wrenches available.
