Loaner Y Climate control seems better than Cybertruck
Bz22
Matt
ATL
F150
One of my main gripes with the truck aside from it already being in service is the climate control fan speed options. I was wondering why there were only 3 settings. In my loaner Y the fan speed has options for 1-10 and different zones beyond the screen controls. Seems superior to the truck in my opinion. Are all other models set up this way?
jf64k
There are only three settings (Low/Medium/High) if the system is in 'Auto'.
MY is the same way. I have two 2020 MYLR's and the climate control settings are identical to my CT when in 'Auto'. When in manual, you get the full range of fan speeds.
Operating Climate Controls (tesla.com)
Stuck4ger
Cape Canaveral, FL
Aerospace
Yeah, the low, med, high are for biasing AUTO without going full manual. You should be able to select manual and increment the fan at will. My experience is those less tech savvy will regulate the fan speed and temp up and down as a reaction to a momentary “I’m hot/cold” and then chase it a few minutes later. I try to push for more subtle changes including use of the seat heating/cooling (which is effective for when someone is in the sun and the other isn’t).
Bz22
Matt
ATL
F150
Interesting. I’m for sure less tech savvy and will look into this when I get the truck back. Thanks.
