ModelAZ
Joe
Marin County
Cybertruck Ordered
BREAKING 🚨 A new patent, US 2025/0364562, published on Nov.27.2025, reveals the scientific breakthrough that allows Tesla to finally transition its 4680 cells from a "hybrid" manufacturing model to the fully dry electrode process that has historically been impossible to mass-produce 🔋
🚧 This patent arrives at a critical juncture for the 4680 program.
While Tesla has successfully mass-produced 4680 cells for the Cybertruck, these "Gen 1" cells are effectively hybrids: they utilize a dry-coated anode (which was successfully implemented early on) but still rely on a traditional wet-slurry cathode.
The wet cathode process proved extremely difficult to replace because the powder was too brittle and abrasive, forcing Tesla to retain massive, expensive drying ovens and solvent recovery systems for half the battery.
This patent outlines the "Gen 2" dry cathode fabrication process that finally eliminates these steps.
⚡ The core innovation lies in the development of a specific polytetrafluoroethylene (PTFE) composite binder material.
While PTFE is valued for its fibrillation properties—a unique ability to stretch into microscopic "hairs" that physically bind powders into self-supporting films—it historically suffers from electrochemical instability at low voltages.
This degradation leads to excessive lithium consumption and Irreversible Capacity Loss (ICL), which is the amount of energy capacity permanently lost during the battery's first charge cycle.
Tesla’s solution mitigates this by combining PTFE with chemically stable binders—specifically polyvinylidene fluoride (PVDF), PVDF co-polymers, or poly(ethylene oxide) (PEO).
⚛ The necessity of this composite approach is highlighted by the severe performance penalties associated with using pure PTFE. The patent details that PTFE possesses a relatively low Lowest Unoccupied Molecular Orbital (LUMO).
In quantum chemistry, this level acts as a threshold for stability; because the LUMO is low, the PTFE is "too eager" to accept electrons from the anode. At low operating potentials, charge transfers into the PTFE structure, causing defluorination and the formation of lithium fluoride and polyenes.
📉 Pure PTFE dry electrodes suffer an ICL of approximately 127 mAh/g. When benchmarked against industry baselines—where mature wet-slurry graphite anodes typically exhibit an ICL of only 20 to 35 mAh/g—the pure PTFE performance is nearly five times worse.
This inefficiency renders pure PTFE dry electrodes commercially unviable, as they waste a significant portion of the battery's lithium inventory on side reactions before the device is even utilized.
🛡 To overcome this deficit, the patent introduces a composite binder system where PTFE is mixed with materials like PVDF or polyethylene (PE), which possess higher LUMO energy levels (higher stability thresholds).
These added polymers effectively coat the electron-conducting materials, creating a barrier that prevents direct contact between the unstable PTFE and the active electrode materials.
✅ Performance data validates that this method elevates dry electrode technology to competitive levels. For instance, substituting pure PTFE with a polyethylene binder reduced the ICL to just 30 mAh/g, effectively matching the efficiency of standard wet-slurry electrodes.
Furthermore, a PTFE-PVDF composite processed at optimal room-temperature conditions achieved an ICL of approximately 50 mAh/g. While slightly higher than best-in-class wet anodes, this represents a massive improvement over the pure PTFE baseline, bringing the dry process within striking distance of commercial viability.
⏱ Crucially, the patent solves the "throughput nightmare" that has long stalled mass production. Dry coating involves calendering—smashing powder into a film using high-pressure rollers. In previous attempts using pure PTFE, the material required ten passes through the rollers to stick together properly, a rate far too slow for high-volume automotive manufacturing.
The patent notes that the new composite binder formulation achieves a cohesive film in only three passes. By effectively tripling the speed of the manufacturing line, this innovation allows Tesla to finally hit the production targets necessary for mass-market vehicles.
🌪 Beyond speed and chemistry, the patent addresses the physical durability of the cathode film. Early dry cathode attempts suffered from high scrap rates due to "dusting," where the brittle ceramic powder would crack or turn to dust when wound tightly into the can.
Tesla describes a specific high-shear jet-milling process that fibrillizes the composite binder into a specific "spiderweb" microstructure. This turns the brittle powder into a flexible, self-supporting film capable of withstanding the mechanical stresses of winding without cracking, transforming the dry cathode from a lab experiment into a reliable industrial product.
🧩 To fully appreciate the strategic value of this manufacturing innovation, it must be viewed alongside Tesla’s complementary patent, WO 2024/147993, regarding "Doped Manganese-Rich Cathode Active Materials." Together, these documents represent a unified strategy to solve the two largest hurdles in battery production: material cost and manufacturing footprint.
💰 While the dry electrode patent resolves manufacturing instability by stabilizing the binder, the cathode patent addresses the chemical instability of cheaper materials.
Manganese-rich cathodes are abundant and affordable but typically suffer from manganese dissolution. The cathode patent utilizes specific dopants to lock the manganese structure in place, creating a cell where neither the manufacturing adhesive nor the energy-storing powder degrades prematurely.
🚀 This combination unlocks the true "ultra-low cost" strategy for the 4680 cell. Moving to manganese-rich chemistry drastically reduces reliance on expensive nickel and cobalt, cutting the Bill of Materials (BOM).
Simultaneously, the 100% dry process eliminates the massive drying ovens entirely. This cuts the factory footprint by approximately 50% and the energy bill by 90%, finally unlocking the dramatic cost reductions that were the original selling point of the 4680 program.
🏗 Industry analysis suggests that while the dry anode was the "easy win," the dry cathode has remained the bottleneck preventing the 4680 from reaching its potential.
In this context, the dry electrode patent provides the "recipe" for the physical film—the PTFE composite binder—that makes dry coating physically possible and fast enough for factories. The cathode patent provides the specific "fuel"—the robust, doped powder—intended to run through that machine.
Together, these patents delineate the blueprint for a cheaper, more durable, and mass-manufacturable Gen 2 4680 cell.
Source:
So can anyone please explain to those of us in the technologically remedial class, preferably in English, why this is such a big achievement and what it means for Tesla?
Planet Earth
$49,900 DM reserved on 11/22/2019. $59k DM delivered 6/26/2026
Tesla is supposedly introducing 4 new battery cells in 2026.
https://www.notateslaapp.com/news/2323/tesla-to-launch-four-new-battery-cells-in-2026
“NC20 Battery
The next size up, the NC20, is intended to power Tesla’s SUV lineup and the Cybertruck. This will be a larger-format cell intended for moving larger and heavier vehicles and possibly optimized for towing—a constraint the Cybertruck, on its current 4680s, can find challenging in harsh winter conditions.”
Fugue
Kentucky
Cybertruck AWD FSD, Model Y LR FSD
Tech Industry Grunt
“NC20 Battery
I want a CyberSUV or Cybervan with more seating than an X.
pricedm
Adam
Denver, Colorado, USA
Great news.. stock price should plummet next week 😂
Also Toyota will announce solid-state battery coming "next year" and Electrek and Jalopnik will pump the "news" lol.
aadams1278
Andy
Wilson, NC
Model 3, Model Y
Pilot
Lower production costs
I would suspect this also means they have the possibility of improved range. The irreversible capacity loss from the first charge decreases about 5x according to the first post.
That sounds like, if Tesla chose to keep the same amount of cells in a pack, that those cells would end up with more energy after the first charge than the prior/current cells do.
That said, they could reduce the number of cells to only cut cost and keep the range the same.
How long before they get put into trucks coming off the line is the next question.
Reducing the number of cells also reduces weight presumably. Does a dry cathode cell weigh the same as its wet equivalent?
aadams1278
Andy
Wilson, NC
Model 3, Model Y
Pilot
Not a battery expert but to my understanding, the creation process is the only part where it’s wet, so I would guess the weight isn’t noticeably different, but that’s purely a guess.
Reducing weight is a valid point, which would increase efficiency, as long as it’s enough reduction to make a difference. For those wishing to tow a decent range with the truck, like me, I think shear battery capacity is going to be the only real solution and weight is secondary. I have my fingers crossed.
kpanda17
Love how EVs have made us more intelligent
