carsly
- Vin
- Dec 13, 2023
- Princeton, NJ
- LR Defender, CT AWD
- #1
I have a 2024 FS AWD and while I do have the spare tire, I always feel better with both a jump starter and air compressor in each vehicle. So shopping I went.
I found this Wolfbox MegaFlow 24 Pro with dual-cylinders designed to quickly reach high pressures up to 150 PSI. Here is my quick unboxing and test video:
Takeaways:
- Quickly gets our massive, high-pressure, Rivian tires up to the necessary inflation pressures
- Quite portable with a nice, durable, carrying case
- Two ways to charge - USB-C and 12V with the ability to run directly from a 12V socket
- 12,000 mah built-in battery that you can also use as a power bank
- Easy to use - power on, connect the hose, set the target pressure and tap again to start inflating. It stops automatically when hitting the target pressure.
- Feels well constructed, solid, unlike the portable Rivian air compressor
Here is the Amazon link if you're interested: https://amzn.to/4relxVO
Questions welcome!
Takeaways:
Questions welcome!
