Tesla Air Compressor and Tire Repair Kit
j4ypal
Philippe
Quebec
Model 3 and CT reservation
So, after reading all the feedback, and doing tiring research and learning just how expensive inflators are for tires Cybertruck sized, $500 for an excellent inflator and repair kit isn’t so unreasonable after all. Sure, I could go with much cheaper alternatives, but if I needed to do an emergency repair and inflate a tire from flat, not much else would work. For most of us, inflators $100 and less would work for 90% of the time. Being prepared for the other 10% might require a more substantial investment.
M18 inflator from Milwaukee will do Semi truck tires so should be good for CT and costs 179$ at Home Depot. It's what I use on my vehicles and work like a charm. It's small too.
Chris Pierce
Chris Pierce
Chris
Central Florida
Model Y and (reservation for) Cybertruck
I wish now I had gone all Milwaukee battery tools, instead of Ryobi. Oh, well.
Gritted Cybe
Tony
Mars
Cybertruck AWD
Really impressive!
Shadowmite
Denver, CO
FS CT, 24' MYP
Honestly its a wasteful spend. You can get a really useful one I use when off-roading. It covers easily all 4 tires on the CT on a charge and is easy to recharge from the truck itself. https://
LASFIT TK1 Tire Inflator Portable Air Compressor [Fit Pickup Truck & Large Tires] Air Pump for Car Tires w/Digital Pressure Gauge, Auto Stop, 150PSI...
Exactly how are you recharging this 12v item from the trucks 48v or 120v or 240v? Can it charge via the USB-C? Maybe that’s what you are saying; Just trying to understand.
Shadowmite
Denver, CO
FS CT, 24' MYP
Seems similar I guess To the Fanttik S100 ($40@Costco) but with a larger battery. Very very slow for our purposes on the cybertruck saying 29-36psi in 2 minutes and only 20 minutes run time per full charge. Heaven forbid you dont get a flat and have to do 0 to 50. I think the Tesla option is still shining here Unless someone finds a really fast/reliable 120v powered pump.
Gritted Cybe
Tony
Mars
Cybertruck AWD
My plan is to buy a 30A 120v to 12v converter. Then I can use my old air pump but also power some LED lights for a camp or anything else that needs 12v.
sys700
Rod
Portage, MI
Foundation Series Cyberbeast (August 2024 - 26###)
I ordered mine in January. Still haven't received it, and they said it was in stock. The app gives me the run around for support, and eventually has me call a phone number with no shop options. Anyone know how to contact Tesla about the status of a shop order? Tesla really has to work on their customer support!
CYBERUN
Palm Springs California
Tesla S, Tesla X and Cybertruck
I discovered my Tesla air compressor and tire repair kit from my Model Y won’t work on the Cybertruck, because there’s no “cigarette lighter” outlet on the Cybertruck. Can anyone explain why I should spend $550 for the Tesla equivalent Cybertruck product?
Nobody forcing you to spend. It’s optional and great if you do off-road on daily basis.
cybercricket
Oregon
Don't even need as beefy as 30A, I believe cigarette lighter adapters are typically fused at 10A. If there is a need to run more than one 12V accessory then having multiple of these could be more convenient given 120V outlets on CT are in different locations :
https://www.amazon.com/s?k=interlock&crid=2U2SACZ3J5S8P&sprefix=interlo,aps,253&ref=nb_sb_noss_2
Still, I am confused why OP is perpetually confused. What was your MOS in the Navy ? :)
arodriguezfeo
Orlando, Florida
There is another thread that discusses option to the Tesla compressor. I own the Tesla one, but I almost bought another 120v charger made by TC BL. It is powerful and fast but does. I read that it does not have the same auto shutoff that the Tesla one does so you have to know what you are doing.
TC·BL Portable Air Compressor 110V,Ultra Quiet Air Compressor Oil Free and Lightweight Small Air Pump
https://a.co/d/h49ceA7
Chris Pierce
Chris Pierce
Chris
Central Florida
Don't even need as beefy as 30A, I believe cigarette lighter adapters are typically fused at 10A. If there is a need to run more than one 12V accessory then having multiple of these could be more convenient given 120A outlets on CT are in different locations :
Confused why the Tesla air compressor is so expensive? Not anymore, after seeing these replies and doing more research. I appreciate the value of “crowdsourcing” to help me understand.
MOS: Electronics
The Tesla Guy
Daniel
Washington
youtubeteslaguy.com
23MS Plaid, 23MY, LR,Order-FoundationCyberTruck DM
Texarado
Dallas TX
Anyone have any idea when the Tesla compressor is supposed to be in stock again? I have one of the original $2500 credits so I’m waiting until I can include this. Most of the other items have now maintained better inventory levels after the initial surges.
