dalton108
Dalton
Lawyer
I’ll admit; I’ve been a pretty good boy this year, so, I’m not surprised that UPS[anta] arrived a day early with my new toys!
I think they look fantastic! You can judge for yourself.
Tesla Cybertruck OEM Crossbars: Received and Installed IMG_1953
Tesla Cybertruck OEM Crossbars: Received and Installed IMG_1952
Tesla Cybertruck OEM Crossbars: Received and Installed IMG_1950
dalton108
dalton108
Dalton
Lawyer
A few things:
1. I bought two sets, but I’m now convinced I’ll only ever use them in this configuration above the cabin. So, I’ll only need two.
2. They are a lot heavier than you would suspect build quality is premium.
3. They have to be torqued to 7.8 Nm but, conveniently, Tesla has provided you with a torque wrench (pictured) set to just that amount.
4. Installation is simple; however, if you have a FS CB with the light bar harness waiting to be installed you’re going to have to move that loop out of the way and it’s a bit challenging. Or at least it was for me. Follow the instructions (pictured) and pull the harness toward you don’t try to push it back. If you pull it forward there’s a little space where you can tuck it in under the appliqué. I still had to cut the loop and straighten it out to make it work but that’s only because I put the mounting plate on before I tucked it in.
5. If you bought two sets like I did, each set has enough striker points for all of your mounting positions so you will end up with extra.
6. They are not straight. They have a nice little arc to them which you can see in my initial photos. Not sure if it’s for arrow or loadbearing but either way - looks cool!
Tesla Cybertruck OEM Crossbars: Received and Installed IMG_1954
dalton108
dalton108
Dalton
Lawyer
I approve!
A great looking OEM accessory that hopefully doesn't whistle driving down the road.
Haven’t driven yet. I’ll report back on that.
Guylouis
Guy
F.S. CyberBeast, XP, YP, 3P
Epic!
mine are scheduled to arrive tomorrow. Pumped
EMoeller
Eric
West Marin, California
Porsches (992 Turbo S, 993 Turbo, 993 Targa)
Geologist
I also ordered two sets (mostly for hauling kayaks). One is set to come tomorrow and the other hasn't yet been received by UPS. It will be interesting to see what the hit to milage (if any) will be?
Guylouis
Guy
Does each package contain two crossbars or one crossbar per package?
I order two sets and received two different tracking numbers so trying to gauge if all four are coming
dalton108
dalton108
Dalton
Lawyer
Each box contains two crossbars. My two separate orders both came at the same time today. So that’s what you’re seeing in the bed of my truck.
Jack27
Randy
None
So my question with these is why didn’t they add some loop points for tie downs or rope or what ever? How are you spose to tie things down properly if you ever use them for other then looks ?
dalton108
dalton108
Dalton
Lawyer
These have a T slot that runs right down the center. Not easy to see because there is a gasket/gromit that runs right down the center filling in that slot. It’s very compliant and yields easily when depressed.
Jack27
Randy
None
Does slot receive a T clip hook for straps or it’s big enough to hook a standard ratchet strap in it ? , seems smart to make some sort of T clips so your tie point is running in a different direction then your crossbar
dalton108
dalton108
Dalton
Lawyer
Guylouis
Guy
Good question. All questions are answered in the little manual in the box. It’s 200lbs max! No increase in capacity gained by using four!
No funky mounting either. Must be adjacent. No skipping from 1 to 3. Must be 1:2, 2:3, or 3:4.
1:4 is OUT OF THE QUESTION!
I honestly bought them purely for aesthetics and my Starlink mini lol
