OEM Crossbars versus MARS Adventure Gear
area51
Neurosurgeon
I have OEMs currently, but will be switching to Mars ones when I can. I like to bomb proof everything I can and, although I haven’t any problems with the OEMs coming loose, you can just tell they’re not the sturdiest things ever made.
Mars sells L-Track adapters so you can mount the crossbars under the tonneau if needed. If Starlink would work down there (not sure if it will yet), that would be ideal. Open the tonneau when you need it or close the tonneau when going through a car wash and to protect the Starlink from theft/vandalism.
My main concern is that I keep hearing that the Mars are louder than the Tesla OEM‘s. I also thought about that with the starlink in the bed but the problem with that is that if it’s raining outside, you don’t want to be opening the tonneau cover.
ABILISK
DFW
‘24 Beast
I guess I don’t think about that much. Don’t see much rain in TX. Our windshield wipers almost outlast our vehicles here.
Here’s a couple pictures of the OEM track system with a thing mounted…(hinge that was part of a makeshift collapsible rack not currently installed).
A couple interesting features not seen in aftermarket versions: rubber insert that holds the bolt in place while loosened, fits commonly available 3/8” carriage bolts, and the ends are secured when locked.
That’s very cool. Thank you. Now I get it.
The Tumbler
AJ
Alamo, ca
2024 Cybertruck FD series Dual Motor AWD
Real Estate Broker
I don’t want racks on all the time so I love how easily the OEM bars are to install and remove. 3 minutes max. I do highly recommend some t slot mounts on the sides given there aren’t any connection points on the bars themselves, which is problematic for the forward bar above the cabin. I got these and they are well made and work perfect.
https://a.co/d/80cb9ep
Tesla Cybertruck OEM Crossbars versus MARS Adventure Gear IMG_0176
Tesla Cybertruck OEM Crossbars versus MARS Adventure Gear IMG_0179
Tesla Cybertruck OEM Crossbars versus MARS Adventure Gear IMG_0177
Tesla Cybertruck OEM Crossbars versus MARS Adventure Gear IMG_0178
Tesla Cybertruck OEM Crossbars versus MARS Adventure Gear IMG_0180
IntoTheRain916
Kai
Sacramento
Model Y, Cybertruck
Business Owner
I can't speak on the OEM bars—never tried ‘em. I did what you're doing now: researched like crazy and went straight for the MARS bars. No regrets. I’ve had over 750 pounds up in that rooftop tent—me, the wife, a 17-year-old, a 13-year-old, and a Cane Corso who outweighs half the Cybertruck. Not a single creak. Zero stress. MARS held it down like a champ—pun fully intended.
Tesla Cybertruck OEM Crossbars versus MARS Adventure Gear 20250420_192654
Tesla Cybertruck OEM Crossbars versus MARS Adventure Gear 20250420_192641
Tesla Cybertruck OEM Crossbars versus MARS Adventure Gear 20250420_192839
area51
Neurosurgeon
Thanks for the detailed photos! I got the Tesla OEMs but thankfully just one kit of 2 bars. I'm so tempted to go for the MARS. I only need two. I was going to get a side sail molle on one side with their utility bar on the other, starlink mini mount and the weboost mount. They quoted me 1300 for all of that.
Is the starlink locked in the mount or do you have to remove it overnight. I'm worried about theft.
Urander
urander.com
How’s the wind noise? Just wanted to share feedback from a Cybertruck owner who recently switched from MarsAG to our setup.
Tesla Cybertruck OEM Crossbars versus MARS Adventure Gear IMG_9753
IntoTheRain916
Kai
Sacramento
Model Y, Cybertruck
Business Owner
Super quick to remove—takes me about 60 seconds with a ratchet I keep handy. I also carry a spare power adapter, just in case a sheep decides to get creative with wire-cutting. My Cybertruck stays garaged and is never left unattended for long with the Starlink mounted. Here in Cali, I’ve never had anyone mess with it.
area51
Neurosurgeon
Sheep as in the animal?
Urander
urander.com
https://www.starlink.com/shop/products/us-consumer-roof-rack-mount-mini
Tesla Cybertruck OEM Crossbars versus MARS Adventure Gear IMG_9754
IntoTheRain916
Kai
Sacramento
Model Y, Cybertruck
Business Owner
I won’t deny I almost went with Urander, it was definitely my second choice. That said, I wasn’t about to drop serious money just to test products. I’d been in several Cybertrucks with different racks, and hands down, MARS and Urander had the least wind noise. Since I was already buying from MARS, it made sense to stick with them. Their mission aligned with mine, and at the time, their design was backed by solid science, unlike most of the others out there. No regrets going with MARS.
IntoTheRain916
Kai
Sacramento
Model Y, Cybertruck
Business Owner
Sheep. As in, “I’ll only drive a gas guzzler ‘cause that’s what real trucks do,” or “Oh no, people are looking at me—better return the Cybertruck and disappear back into the sea of beige Camrys.
IntoTheRain916
Kai
Sacramento
Model Y, Cybertruck
Business Owner
@area51 If you want, I can run a quick test for you tomorrow—have my wife hold the phone at head level while I do the speed limit wink. It'll give you a general idea of the noise level, though, take it with a grain of salt. I’ve also got the MARS wind deflector on the way, which should cut window noise even more. Keep in mind, I’m running a 50" lightbar, MARS Base Camp rooftop tent, rear cam, and a bunch of attachments—still impressively quiet. Let me know!
I'll be working on a solution soon with (probably) EMT so the cables can be protected.
