Replacement tire price will be a shock
Riptide
Roland
Jeeps
This is kind of irrelevant but I wanted to ask how loud massive tires like the ones on the Cybertruck are at speed? How comfortable are they (jittery, bumpy, etc)? Thanks for any help!
It's not exactly about the size of the tires. There are in my experience two big contributors to noise.
The type of tire you select - if you choose a really open tread it's going to be louder than a closed tread designed for a sedan in dry conditions.
Next, if you do get open tread tires then you really, really, need to rotate them regularly, according to manufacturer specs. Otherwise you'll have a problem with cupping, and man does that get noisy.
Also, for any open tread tire it's going to be louder at higher speeds. Worse with cupping.
SwampNut
Carlos
Peoria, AZ
Tesla M3LR, Gladiator Rubicon
Geek
I don't think I've gotten 30k out of tires in decades.
You must drive like my wife drove the Z4 which the M3 replaced. I asked some of my friends how the hell the rear brake pads could be shot at around 35k I think. Normally cars wear the fronts, and at much higher miles. One friend said, "Wait, doesn't it use the rear brakes for traction control when you're sliding around corners?" Ah, yeah, that also goes with the 18k rear tire replacements. Sigh.
Also...truck tires tend to last much longer. I traded a Ram 2500 for our first Jeep, and it would get 60k on its tires, even towing quite a bit (12k pounds).
This is one thing which I think would be quite nice, maintenance notifications. Ideally, the car should track which tire is where and inform you when rotation is due. If you drive like @Crissa, those notifications would be more frequent.
SwampNut
Carlos
Peoria, AZ
Geek
I have a CBR1100XX. I once put tires on it on Friday, rode a long canyon/twisty weekend, and needed a new rear on Sunday. 1500-ish miles. The sides were blue and twisted up. I've never seen more than 7k, but then, it's a much heavier bike than the R1.
John K
Volt, CT reserve day 2
I weighed less too.
Cybertruckee
Yosemite Sam
Mostly under the pines
Red Rider
Finance Manager
That's a problem further down the line for me. My immediate thought is how to much outlay for converting the rest to dually so I can carry that dang Lance 1172 if the CT is permitted as heavy duty. :rolleyes:
SwampNut
Carlos
Peoria, AZ
Geek
That would exceed rated capacity by a lot. I can't see anyone being ready to do HD conversions on a CT for quite some time. That's a lot of liability to take on. And the powertrain warranty...toast.
Cybertruckee
Yosemite Sam
Red Rider
Finance Manager
My question exactly on why Elon application to have the CT classified as MD and HD.
jhogan2424
Moped
One ton trucks don’t necessarily have to be duallys. I didn’t know they were looking to have it classified as heavy duty.
If you try to go dually, you are likely going to have to rebuild the whole rear end of the truck since it's being built around rear wheel steering. Lots of custom/ one off parts.
Cybertruckee
Yosemite Sam
Red Rider
Finance Manager
Am surprised myself when I read it. But then, CT is bigger and wider than the 1-tons out there, so... maybe.
Cybertruckee
Yosemite Sam
Red Rider
Finance Manager
Same question on the render done in this forum(???).
