Tailgate.
Frankenblob
Home
M38A-1, Trans-am
Hopefully the tailgate wont be slippery.
Standard contact sheets for deck gripping would work, too.
Lots of solutions. Might be able to score/texture the metal directly.
Bigvbear
Justin
Eugene, OR
yeah im kinda wondering if the whole vault will be slick when wet
TI4Dan
Dan
MT. USA
Spray in bed liner has a semi rough texture that would eliminate the smooth surface, It comes in some trucks from the factory but can be done by paint shops also.
Grantja9
Jim
Plaquemine, Louisiana
F-150
My concern with the tailgate is that in every picture that I've seen, it's opened past 90 degrees. This makes a flip stop useless, and you can't sit on it. Older trucks had chains that stopped the tailgate at 90 degrees, and newer trucks have cables. CT has neither.
CybrTrkWdWk
Dual Motor FSD
Design, Woodworking
I imagine that was a prototype issue.
myco.rrhizae
Myco
N. Cal
F150 4.9L, Chevy Volt, Tri-Motor Cybertruck
Carpenter
looks level to me
Tesla Cybertruck Tailgate. 05_Deskto
Sirfun
Joe
Oxnard, California
Retired Sheet Metal Worker
looks level to me
Yep looks like on the same plane as the bed of the truck. I''m surprised nobody has mentioned those stripes. Most people think those are grooves or T-Slots that would make the inside of the tailgate an AWESOME workbench! With T-Slots you could temp. mount saws, clamps and other tools directly to the inside surface of the tailgate. Plus, you would have removable raised rubber filler/traction strips inside those grooves when you're not needing to use the T-Slots. In this photo, it looks like the rubber filler strips are in the T-slots, which would raise flat material off the flat SS deck making it easier to grab, plus creating traction. The Cybertruck is AWESOME!!!!!
Frankenblob
Home
M38A-1, Trans-am
I have seen similar pictures. It should stay at 90, as I sit and sometimes fish from the back, heck with this vehicle and a winch I would chance getting much, much closer to a fishing spot than I would normally.
KendrickMB
Kendrick
Richland, WA
2019 Chevy Trax, 2012 Ford Explorer
Teacher
Nice, I wonder how they get it to stop at different angles, and if there'd be a weight limit at 90 degrees.
I'm wondering the same thing. Rewatching the Jay Leno segment, it appears the tailgate goes past 90° when Elon stands on the bed cover.
Tesla Cybertruck Tailgate. Screenshot_20201107-220626
myco.rrhizae
Myco
N. Cal
Carpenter
Im very excited about all the possibilities for the T-slots. That is a very good point about the functionality of the rubber filler strips. Genius!
