Somugo
- Somu
- Jan 25, 2023
- Ohio
- N/A
- IT
Hey, looks like you were taking pictures in my garage.I have the same issue although only about 3” total. Since I bought parking bumpers on Amazon I have had no issue parking. I used double sided tape to secure them and they work great. There is enough downward force from the tire once you’re on them that they don’t move at all.
The trick is to change height to entry so the height is always consistent and use a landmark on the camera to know when to stop but the bumpers keep you safe.
Might be easier to pull in instead of back in btw.
https://www.amazon.com/dp/B09RGKDVBM?ref=ppx_yo2ov_dt_b_fed_asin_title
When your wheels hit the first lower curve, you can be sure it is right spot to stop now. And the second higher curve will block your wheels nicely in a slow move.
The catch is, it will move itself as well every time you push it when you park, in spite it has been glued down to the floor. I do want to bolt them to the floor that would end up some holes. So sooner or later it would need to be re-positioned again. So far I have used it for a couple of months now and may need to do so next month for the first time I guess.
