Towing Height
Fleetwood75
Orange County, CA
2024 Cybertruck AWD Foundation Series 2022 Model X
Structural Engineer
In the owners manual it recommends towing at Low height, but I tow my camper on dirt roads and I’m worried that Low could be too low on rutted out roads with pot holes. The manual also said that in tow mode that the truck will hold at medium or low. I haven’t towed yet but I’m curious if any of you have. If I manually put the truck in medium and then connect a trailer will it hold in medium? I’m trying to figure out what drop I need in my hitch to buy a new one
Speedr
Dual Motor Cybertruck
@Fleetwood75, it seems to default to Medium whenever I tow anything, and it stays there at all speeds, unlike when it's set to Medium without a trailer (i.e. it lowers to Low at highway speeds).
Fleetwood75
Fleetwood75
Orange County, CA
Structural Engineer
Okay thanks for that tip! I wonder why the documentation says low. When I force the truck into medium I measured 18.5” from ground to inside top of hitch receiver, does that jive with what you’re seeing?
CyberTruckeeTheOne
Andrew
Milpitas
4runner
My impression is that the CT on tow mode levels to the trailers since mind is level with the RV.
Yes, used a level to check.
And I want it to remain that way as I drive with it.
Once, I never even deployed the weight distribution system and it's stable.
