- A. J.
- Dec 8, 2019
- Virginia/Quebec
- Tesla X LR+, Lexus SUV, Toyota SR5, Toyota Landcruiser
- EE (Retired)
The PW 2 has a capacity of 13.5 kWh (compare to 200 kWh and perhaps even more battery for the tri motor) and can only deliver 5 kW peak (implying 12.5 miles range added per hour of charging). But why take energy from the utility, store it in a battery and then dole it out at a slower rate to the car? If you can buy it at a cheaper rate during some hours which don't happen to be the ones during which you charge then of course that's the answer. I'm in Quebec and there is no such staggered rate structure so there is no such advantage. And even where there is the lowest rates tend to be offered at night when you are most likely to be charging your car.I live in Northern Ontario and am wondering about the tesla wall as an option for charging the cybertruck.
Given that you are in northern Ontario you should be thinking about other reasons for wanting a solar roof as I don't believe that charging the car should be the main consideration. The two long poles in the tent are the latitude and snow. High latitude means reduced production from panels, summer and winter, because the sun never gets very high in the sky meaning that unless the roof is pretty steep (as it may be for snow shedding) you never get the sun's rays close to perpendicular to the panels. This can be made up for by adding extra panels and is somewhat also offset by longer summer days. Assuming that you size a system reasonably for summer it will be pretty useless in winter when the sun't elevation is very low and the days are very short. This is why I suggest that the car is probably not the main motivator. You probably drive as much in winter as in summer and you will use more energy per mile driven in winter. A solar system produces minimum energy when you need it most not only for the car but for heating (if you use electric heat as, of course we do in Quebec) and for lighting.Were also looking at redoing our roof. Should I be thinking about the solar roof in conjunction with the tesla wall?
From the ROI perspective you need to thoroughly understand your supplier's position on solar. Hydro Quebec, for example, is most uninterested in supporting it and so does not purchase any excess generated (but will, I think, allow net metering thus not charging you for what you don't take from them).
As to the environmental aspect: Adding solar to a residence supplied by Quebec Hydro or a utility who buys heavily from them doesn't do much, if anything, to minimize CO2 production. The story is different if one is far enough north that the local plant trucks diesel in across the ice roads for a substantial part of the year.
Bottom line is that up north the question is not a simple one to answer. Powerwall for emergency power? Perhaps but we have already had a 3 - 1/2 day outage this season during which we used 169 kWh of electricity (heat pumps + baseboard electric). We'd have needed 13.5 powerwalls to carry us through that.
