Deleted member 3316
Guest
In the Cybertruck config I was thinking portal hubs on fully independent suspension all around.If you liked that then I’m sure you’ll like this.
I think a setup similar to this on the Cybertruck would be epic.
Giving ground clearance (not running clearance or suspension clearance or whatever BS OEMs use to give a bigger number) of around 350-400mm!
The winch spool and gearing could be mounted in the dead space under the tray, forward of the rear drive unit. This would negate the need for a moveable unit or two winches front and rear.
love this post if you want a Power Take Off (PTO) winch!!!!
