wow thank you so much for sharing this, its always a huge help to usJust got my CT AWD and the Cyber Safe Vault showed up the same day! It is AWESOME! love it. Highly recommended and took just a minute or two to install.
wow, we want to make a frunk net as well. may I know how the OEM frunk net is installed? is that simply a couple of screws?Installed my frunk mat, fits great! Was able to also cut a couple holes easily so my frunk net can still be used. Great combo, helps hide the exposed frunk net bolts.![]()
Thank you so much for the feedback!I installed the BestEVmod/EVVida frunk mat today. It works well. I like that it fits directly into the spot with no adjustments necessary. Plus the material is malleable enough to cut holes for the Tesla frunk net if I decide to get it later. Highly recommend for anyone who wants a bit of frunk scratch/liquid protection.
Here is the before and after. Not a big difference but that’s the point so it looks OEM.![]()
You pry up two plastic access panels, then using the same four OEM bolts, attach a bracket similar to the vaults Ltrack. the net connects to the bracket and can slide along the track to adjust the stretch.wow, we want to make a frunk net as well. may I know how the OEM frunk net is installed? is that simply a couple of screws?
thank you very much. we appreciate that.You pry up two plastic access panels, then using the same four OEM bolts, attach a bracket similar to the vaults Ltrack. the net connects to the bracket and can slide along the track to adjust the stretch.![]()
Looks great! Would be interested to know where you got that, or how you made it?Added a little graphic to the tailgate.
