flamaest
Fabian
Hollister Ca
Systems Engineer
Great news, Breezer windows just finished designing their removable rear window system so that you can sleep in the bed of the truck in comfort.
https://breezerwindows.com/product/tesla/
The special thing about this design is that it can be purchased with a hose setup to push 2nd-row air conditioning into the bed while the truck is in camp mode.
This is an awesome solution for camping and it will go well with the systems I have next to put into the cyber truck, like a bed, refrigerator, microwave, tools, and accessories.
Below are the latest design photographs and I will be adding to these images with more photos and videos as soon as I get mine installed.
I plan on crossing the country with my Cybertruck with this design in 2025.
Tesla Cybertruck Breezer Rear Window Replacement System for camping / sleeping in bed! 💨 Pumps cabin air into bed vault IMG_2261
Tesla Cybertruck Breezer Rear Window Replacement System for camping / sleeping in bed! 💨 Pumps cabin air into bed vault IMG_2260
Tesla Cybertruck Breezer Rear Window Replacement System for camping / sleeping in bed! 💨 Pumps cabin air into bed vault IMG_2262
Tesla Cybertruck Breezer Rear Window Replacement System for camping / sleeping in bed! 💨 Pumps cabin air into bed vault IMG_2263
Tesla Cybertruck Breezer Rear Window Replacement System for camping / sleeping in bed! 💨 Pumps cabin air into bed vault IMG_2264
countryboy
East TN
M3P | CT FS AWD
I was hoping to reach thru to grab snacks or whatnot, but pretty sure my arm would barely fit even if the grill was removed. This obstructs rear view when tonneau is open too. Not sure I camp enough to want this on the daily, can already run a hose out another window...
How much were you going to see out the window anyway?
I just want it for the fresh air and managing the pressure differential.
countryboy
East TN
M3P | CT FS AWD
Mirror is currently useful off-road, with people or pets in the bed, in the dark, when hauling dirt bikes or anything with tailgate down, or any other time rear camera is useless. I like driving with tonneau open a lot and prefer the mirror over camera. Making the tiny window smaller with dense grid would hamper that significantly. Don’t get me wrong, it’s great to have an option for rear window airflow and this is slick. Just wish it was clear and had as thin frame as possible.
That's... a minority opinion, but it's an opinion. Anyhow, if you don't focus on the grid, you'll see through just fine, just like our ancestors looking for lions through the leaves of the forest.
flamaest
Fabian
Hollister Ca
Systems Engineer
Gee, and I was just looking for something I could open and close.
I hadn't thought of using a grill... I wonder if they would make it with mosquito netting instead?
The tunnel cover does not have a sensor to stop when opening, so if you have an item through the rear window and somehow the tunnel cover is opening , it will not stop.
freedomwan
Freedom
Gales Creek, Oregon
F250 7.3L - Cybertruck AWD Foundation
Lithography
Can you provide any details on how the install goes? How handy do I have to be? I have no idea how removing the rear glass works?
aeroguy
VA
It reverses after enough force (found out one day when it partially rolled up with an L-track hook caught inside)…but I would really want to see a manual cut-switch relay that activates when the window is removed and cuts the power to the motor or controller. This could be a simple pig-tail style relay/switch extension cable that plugs in between the body controller module and the actuator itself.
wtibbit
Wayne
DFW
Pretty soon... on the Breezer website...
Option Two:
No mosquito netting ---- $0.00
Mosquito netting ------ $199.00
aeroguy
VA
I can’t tell, but looks like you have both options - open window, opaque abs, clear abs, and a mesh with air hose connection. Would probably attach a insect screen to the mesh insert for camping.
Same question…would really like to see a non-destructive method to remove the rear glass.
wtibbit
Wayne
DFW
Most questions that start with "How do I remove the....?" for the Cybertruck are at least somewhat answered in the Cybertruck Service Manual, which is available to all of us.
Here's where you'll find the answer to your question.
https://service.tesla.com/docs/Cybe...UID-35DDF56A-8DB7-4A9E-9BD6-A348483438A7.html
Don't try this at home, children, unless you have an Equalizer Express 360 (220V) and know how to use it.... (Caution: knowing how to do a Google search and skimming the results is not the same as "knowing how to use it.")
This isn't correct.
it would crush anything that fell into it opening or closing and probably violate NHTSA's safety rules.
Not that I stick my fingers into it, but sheesh.
Don't try this at home, children, unless you have an Equalizer Express 360 (220V) and ...
I was curious and read the description of what they were using thise tools for...
People doing things at home aren't in a time crunch and don't need a fancy power tool to cut urethane glue. That tool is just an industrial version of an oscillating cutter. You're not supposed to be cutting the glass!
At least read the instructions before you assert what someone needs to have.
