Deleted member 5322
Guest
Solar is not, Tesla is!solar isn't that expensive.
compared to a GM Bolt.Solar is not, Tesla is!
I think you might be lowballing what 15 miles / day looks like on the cybertruck. Obviously it will vary greatly from weather, etc. So let's just cut it in half and look at the ball-park estimated numbers, which I hope are also low:You run all that off propane? Either way, electricity is not the solution for heating.
A heat pump is more efficient than a resistive heater.You run all that off propane? Either way, electricity is not the solution for heating.
True, mostly.A heat pump is more efficient than a resistive heater.
So much so it's more efficient to run a small mini-split off a natural gas generator than to burn that gas for heat.
(But no, the tonneau is not going to keep your toes warm).
15 per Elon's tweet... Almost a full commute for me. It would be nice if it at least cuts the vampiric drain.You know the solar tonneau will add less than 10 miles with a full day of sun right?
IMO this is the big problem with camping in the bed. Adding HVAC to the vault isnāt going to cut it for camping. It works quite well for the cabin because the cabin is fairly well sealed and insulated. Even the cabin glass is designed with laminated panels to insulate it. The vault is not insulated at all. Blowing warm air is damned near like blowing it outside. The vault cover is likely aluminum or steel sheets which have near zero insulation and would likely have a ton of condensation on them if you slept in it with warm air blowing into the vault.(But no, the tonneau is not going to keep your toes warm).
He exaggerates.15 per Elon's tweet... Almost a full commute for me. It would be nice if it at least cuts the vampiric drain.
Solar capacity is almost always quoted āUnder ideal conditionsā. If you park the truck in the hot sun angled south in Southern California⦠Here in Oregon maybe weād get half that. A third in the winter.He exaggerates.
The airport is a good point for most, but typically not me.Solar capacity is almost always quoted āUnder ideal conditionsā. If you park the truck in the hot sun angled south in Southern California⦠Here in Oregon maybe weād get half that. A third in the winter.
Thatās all aside from the point. Going camping and not having the battery discharging every day is what Iām looking for. Going to the airport and returning to a full battery after 2 weeks in Hawaii. 5 miles per day is fine.
Unless itās an underground garage, you should still get some charge. Particularly if you hunt a little for a south facing outside space.The airport is a good point for most, but typically not me.
But yeah, I guess it would be beneficial in the summer and I part in a lot or top level of the garage.
- I usually park in the airport parking garage if parking at the airport (covered).
- During the winter, a snowfall would render the solar panels nearly useless. (Snowfall also the reason for the first bullet point.)
Cool. I was watching a Lightyear rep talking about their new car, the Lightyear 2, which is covered in panels. They have a CD of 0.17 which is insanely good. Their car can generate 48 km per day. How long of a day? They didn't say. But they did say that they did an engineering study and said that someone could go 7 months without having to chage up. Now, I'm not expecting THAT level of charging, of course. It'd be neat if they had some clear solar they could put on the roof of the CT. It should be easy enough because it's all flat up there. Anyway, I only commute 17 miles a day so the cost savings for me just won't make it worth paying $1,500 for solar but I'm going to anyway. I'd like to get away from vampiric loss which my wife complains about in her MY.I generally only drive 2-3 days a week and my carport (no garage) is south facing. So there is a solid chance I can average 2-5 kWh per day from solar. There is a solid chance I could get away with only plugging in once a week. That means I donāt need to install a second wall connector. Thatās a $1000 savings right there. I would also save about $70-100/ year on charging. Not a ton, but worth another $500 or so.
Essentially if solar is less than $1,500, itās basically free for me. So the question is how much I would be willing to pay to add solar for camping trips.
