Air suspension noise
RoboTaxi
Kansas
Beast when the gods bless me
If you ever messed the the ride height when driving around it geo-locks it in. When you return to the spot it readjusts to the previous height. You can clear all saved geolocations.
I mention this because when I first got the truck I was adjusting the height at stop lights, getting familiar with the truck. When returning to the light it will adjust to the previous setting at that location.
Technupe
Boston, MA
Model X Plaid, Model Y
fair I saved high on a couple locations when I first got the truck. It could be the truck readjusting so often as well.
nachotaco
Cybertruck, Model Y
I scheduled a visit to my local service center about this, and they told me it is working as intended. They did show me a neat feature. If you are experiencing something weird that you want to report, you can press and hold the car icon in the bottom left hand corner for 5 seconds. This will save a snapshot to make it easier for the techs to check the logs. Snapshots are good for 2 weeks.
juicebeast17
Hugo
san diego
Is anyone experiencing annoying thump noise coming from suspension at low speeds going over rough streets ? Sounds like something is loose. Almost as if I driver over potholes.
Curious if any of the contributors to this thread (or new folks reading it for the first time) ever identified what causes the random suspension relief "poof" sound and noticeable bump/bounce in the truck when it happens?
I've only had my CT for a week now and have noticed it twice, both while sitting idle (but in Drive). The first time I was in a drive-thru and at first thought the car behind me hit me, as there is definitely a noticeable bounce/bump that occurs.
I noticed slight popping and creaking in the first few weeks of showing off the truck to random people when switching from entry height to full extract. It eventually got quieter, so I chalked it up to a break in period.
I didn't know this one! thanks!
juicebeast17
Hugo
san diego
I noticed that the suspension does rattle a lot when going over certain, cracked roads with lower suspension. Feels like I’m driving with lo pro tires, similar to the 20”s on my model Y. Is this something common even in lower suspension mode ?
cyberowners
Mike
Asheville NC
Model 3 Performance, Model Y Performance
I'm hearing what sounds like a quick air release when I turn after sitting at a red light or stop sign sometimes. I don't know how loud it is outside, but inside it's pretty loud. Sounds like it's coming from the right rear.
