Air suspension
SEER
Pete
New Hampshire
Outback, ZR-2, K3500 dually, Cybertruck
In the reveal presentation the rear suspension is lowered when the ATV is loaded. Who did that and when? It almost looks like it started to lower immediately before the shot goes to the ATV.
Any guesses/ideas? Perhaps it occurs with FOB
SEER
SEER
Pete
New Hampshire
I thought about that too for loading with a ramp. But that can't be a default setting. Loading most stuff I wouldn't want it lowered. We'll see eventually.
BadgerCooperative
Nope
nonyobidness
Dual Motor AWD wartHog
Why?
From the demo ride videos; it appears that the screen had a sliding tab which moved through (3) standard positions. So, it will probably better than that, once we get them in hand. I can't imagine Musk taking things OUT of the trucks, that were in all these videos.
TrailHiker
Virginia
I have an air suspension on my Audi Q7 and it is fantastic. I was excited to see that it will be standard on the Cybertruck. It makes a lot of sense to have self leveling when loads in the rear vary from zero to 3000lbs+.
Old Spice
Mars
AccuAir suspension, you can use remote device. Hope they add that feature to the app.
Hadn't thought of that until now. Think of all the cool new functions we may see on the app - suspension adjustment, opening/closing bed cover, raising/lowering tailgate.
I'm also hoping the onboard air compressor is somehow integrated into a tire inflation/deflation system so that you can easily air down or inflate at the press of a button and via the app.
KuMX
Ku
Socal
Cybertruck AWD + 2017 Model X
I'm hoping for more than 3 present heights. Since the air suspension height will be controlled via slider, I hope we're given ability to adjust infinitely within the slider's entire range.
That would be so cool! I used to hate letting air out and putting it back in for driving in deep sand.
Delusional
Phil
Pittsburgh
F-150
Construction
Why not have everything run on air? It's very versatile.
Trains have used air to hold their brakes open since the 1880's.
Tractor trailers use air in the brakes and suspension.
Older military trucks use air to run the wipers.
If you can fill a large enough reservoir you can move just about anything with air.
The problem is when you get a leak the entire system goes kaput.
Don't forget that this also gives you vacuum.
ICE engines use vacuum all over the place.
Devix
Fabrizio
Italy
www.youtube.com
Tesla Model Y Performance
It was a demo vehicle. There would have been a remote control.
I had air suspension in my Model S and now I have them in my Jeep. Awesome!
considering the massive excursion in the Cybertruck, we’ll love it!
Skidmarks68
Todd
Seminole
Toyota Tundra
Radtech
As a lifetime truck owner, one thing I am constantly fighting with suspension is the higher it goes the more body roll you get in turns. One of the reviewers who had gotten a ride after the unveiling mentioned how much body roll it had in the corners. Lets hope this isnt the case.
