Back up power in this crazy freezing temp
iproduce
iproduce
Steve
Franklin, TN
Cybertruck, Model S, Model X
Producer
Ok, so I tried parking it in my garage last night (which was not fun when your garage is not set up for another car...had to move a whole lot of stuff but when your motivated you will do anything..ha!) and left it in there for another hour or so after driving it around some more (roads were not very good and fallen trees everywhere)...anyways that still did not work...so I gave up. Luckily the power came back on around 3am so then had to get up turn all the kids lights off while they were sleeping, etc and decided I might as well move the car back outside top of the car off and plug it back in. Woke up with car fully charged and then I decided to try the trick some have suggested as setting a charger destination and have it pre condition the battery and defrost car...it worked!! So it is now sitting in the garage staying warm in case I need it...and just to be clear our garage has a different power source from the city so to have our wall charger moved into that garage it would be way out of my budget right now to do. Anyways hopefully this helps anyone else that might experience this who parks outside.
Gaximus
Mead, CO
Software Developer
If you are on an iPhone, and I’m sure Android has something similar. You can create a shortcut, that turns on preconditioning. This will warm the batteries, and get the cabin ready. For some reason this option isn’t available in the Tesla app, you can only get it as a shortcut. I have a shortcut that I have enabled that runs when I turn off my alarm. It asked “are you going to work” if yes, it preconditions my truck. By the time a take a shower and get ready, the snowflake is gone.
iproduce
iproduce
Steve
Franklin, TN
Producer
Oh wow, can you give a step by step via iPhone for this? I am not sure how to create this shortcut. Thanks!
Jager
Jeff
Virginia
Like the OP, I live in a rural area and depend upon my Cybertruck as "Plan A" to provide emergency backup power for my home. That's a critical issue for me because without power I don't have running water - I am on a well. And without running water my pipes will freeze (98-year-old farmhouse).
Unlike the OP, I don't have PowerShare. I utilize the 9.6 kW available at the outlets in the bed.
Just to clarify, warming the CT's battery pack is quite easy and only consumes a few percent of available pack charge. Just turn Climate on from the app. That's it. Do NOT turn on Window Defrost or Windshield Wiper Defrost or Heated Seat or Heated Steering Wheel or anything else. Just Climate.
If the pack temp is cold enough, pack heating will begin (in addition to cabin heat).
Here's an example of that pack heating process, from just a few hours ago, with a CT NOT plugged in:
Tesla Cybertruck Back up power in this crazy freezing temp Battery Pack Heating - Not Plugged In
Of note, had the vehicle been plugged in and had access to house power the pack heating would have continued for another ~15 degrees. The BMS set point is different for plugged-in versus not plugged-in. Tesla has also tweaked those set points across different software releases. This was on 2025.45.8.
Also of note, if your vehicle is plugged in it will very likely begin charging at some point (because you've dropped far enough below the set charge level due to the losses from cold and from Climate being on). Turn charging off when that happens. Use all available power to heat the pack, then worry about charging.
And, yeah, it's unfortunate that Tesla does not provide access to pack temps through the normal UI or app. Having access to that information is the singular reason I use 3rd-party apps.
Hopefully for the OP, simply raising pack temps using the Climate control will resolve his problem.
However.... there may be more to the story. There was for me.
I did not lose power during the recent storm. But like millions of others I prepped for that possibility. In my case, that meant bumping the charge level of my CT to 80% - rather higher than I normally keep it - and then unplugging and backing the truck up next to my house (not plugged in, as my L2 TWC is located at one of my sheds, 175' away). With the truck parked, I ran a 50' generator cord from the 240v outlet in the bed to the single-circuit transfer switch at my well head; and a 10 AWG extension cord from one of the 120v outlets into my home for ancillary power. The tonneau cover remained closed; but the tailgate had to be open because of the cords. To prevent snow ingress I draped a canvas tarp over the rear of the vehicle.
Tesla Cybertruck Back up power in this crazy freezing temp tempImageXufDOg
Tesla Cybertruck Back up power in this crazy freezing temp tempImage0dX9Nz
This setup worked great during two winter storms last year, where we did lose power.
Alas.
Eighteen hours into this year's storm, which began as 6-8" of snow before turning to sleet and freezing rain - but with utility power still going strong - I decided to run some THD (total harmonic distortion) comparisons from the comfort of my living room. I also had my "Plan B" backup (a Honda EU7000is inverter gas generator) set up and it was one of the few times I had ready access to all three power sources.
Plan B:
Tesla Cybertruck Back up power in this crazy freezing temp tempImageD9XSDR
Tesla Cybertruck Back up power in this crazy freezing temp tempImagex8XAIf
Utility power measured very clean, as expected: 123v, 60.01 Hz, 2.1% THD.
Turning to the Cybertruck (which I knew would likewise be clean, as I had measured it a year ago), I turned on the bed outlets via the app. A couple seconds later the extension cord I had run to the truck went hot.... but, then, in a surprise, just as quickly went back off.
The CT was throwing an HV_BATT_a294 error and telling me to reset the outlets directly on the truck's screen.
The long and the short after numerous attempts.... resetting the error on the truck's screen would initially clear the fault. However, every attempt to then re-energize the bed outlets (even with both cords unplugged) would result in the fault reappearing.
My "Plan A" was dead in the water.
Service Mode didn't provide any other insight, other than that it also contained a bunch of PCS2_a103_IsoTempSensorIrrational codes. I had to laugh at those. The CT apparently thought about as much of this weather as I did.
The rest of this is speculation, so feel free to take it or leave it.
I do NOT think the truck is broken. I have not booked a service ticket.
What I think happened was that the sustained cold temps (ambient had been 16-18F for many hours) combined with the high humidity from the storm - it wasn't foggy but the air was otherwise dense with moisture - and that perhaps exacerbated by my leaving the tailgate open overnight.... led to a ground-fault or isolation-fault within the (not hermetically sealed) inverter subsystem.
Tesla's leakage current thresholds are very conservative - that's a good thing. But the downside of such safety-conscious design is a narrowing of the environmental envelope in which that design can work.
The next day - yesterday - the storm had passed. It remained very cold, but the sun came out and humidity noticeably decreased. I warmed the CT's pack (using Climate, as described above), moved the truck back to its normal parking spot next to the shed, bumped the charge back up, and let it rest in the sun all afternoon.
This morning, with the truck once again backed up to the house, I energized the bed outlets and they stayed on. Still very cold (ambient of 7F), but much drier.
Numbers were excellent: 119.8v, 60.01 Hz, 2.2% THD.
My conclusion at this point is that the Cybertruck remains an excellent alternative for powering one's home if grid power goes down. But there are likely environmental conditions which can cause it to fail earlier than some other solutions (like a good ICE generator).
In the future I'll leave the tonneau and tailgate closed. Opening them only in the event that we lose grid power. Hopefully that will help.
Along with having a "Plan B."
Alas.
Plan B:
Regarding outlet fault. I've had the same issue when engaging them from the app. However, they stayed on when turning them on from the truck.
Gaximus
Mead, CO
Software Developer
https://www.icloud.com/shortcuts/3dbdb994600f4e99964cbf92e1bdbdb3
That should just install the shortcut for you. You'll need to select your Vehicle when it opens(If you only have one Tesla it might not need to be selected.)
Then tap the share button at the bottom, and tap "Add to Home Screen" and you also add it to an automation, middle tab in the shortcuts app, choose"When something happens" select Alarm is stopped, then select the shortcut. Then when that alarm goes off, and you turn it off, it'll ask if you're going to work and will run the precondition.
no%X#XMVk65v#cq
J
CT FS AWD
Alas.
Plan B:
Maybe you can answer a question for me since you've obviously thought about this more than most.
All of the setups I have seen using the Cybertruck's 14-50 outlet immediately step it down to 30 amp. Is there a reason for this? Is it just because 30 amp is more common in the RV and generator world?
What I'm picturing doing is setting up a transfer switch with multiple circuits on 50 amp equipment to take advantage of the full 40 amps the Cybertruck can output.
Am I crazy?
Am I crazy?
Yeah, 30A is more common for generators.
Note however, RV 30A is 120V, not split phase 120V/240V. RV 50A is 129V/240V.
iproduce
iproduce
Steve
Franklin, TN
Producer
Outstanding! Thank you so much!!
Here's a graph of my pack temperature over the last 24 hours:
Tesla Cybertruck Back up power in this crazy freezing temp IMG_1872
The two spikes are when I enabled "Defrost Truck" from the App (I didn't actually drive anywhere). I presume that just enabling Climate will have similar results, and will use less power.
Beetlebug62
Ken
Maine, USA
Alas.
Plan B:
Interesting. I had those irrational temp sensors, way back on Dec 28th. I have forgotten why. I took a pic of it.
Tesla Cybertruck Back up power in this crazy freezing temp IMG_1622
Jager
Jeff
Virginia
Aye, when it first faulted that was my hope.... that it was some anomaly within the app. Alas, everything else I did was from the truck's console... to no avail.
Jager
Jeff
Virginia
Am I crazy?
No, not crazy.
As @mongo mentioned, 30 amps is far more common in the generator world.
A multi-circuit transfer switch would certainly work. But you'd need to be cognizant of what kind of loads you'd be powering, when. In particular, you'd need to be familiar with inrush current, LRA rating, time of use, and duty cycle of any kind of serious load. Any kind of continuous load would de-rate the Cybertruck 14-50 outlet to 32 amps.
No, not crazy.
Cybertruck 14-50 is good for 40A continuous. The 80% derating need not be applied to its output (which is 80% of a 14-50's limit).
